Author Topic: Need New Engine  (Read 1180 times)
kylebrose
Need New Engine
« on: May 19, 2017, 02:15:39 PM »
I bought a 2010 UXV 500 from a friend for cheap that he said didn't go into gear. Started tearing into it and found out that the cases cracked from bevel gear failure. Also since there was no oil in it i believe someone was running it cause the cylinder is damaged and has signs of oil starvation. Does anyone know where I can get another engine without having to buy every piece of this engine from a dealer?
airshot
Re: Need New Engine
« Reply #1 on: May 20, 2017, 12:25:51 AM »
     I would think you could order one directly from Kymco already assembled.
kylebrose
Re: Need New Engine
« Reply #2 on: May 20, 2017, 03:12:58 AM »
I tried to go to the dealer and see if they could maybe get an engine from Kymco but I never heard from them and it's been more than 2 weeks. I've called a couple times to talk to the guy who helped me and he's never there when I call. Finding an engine for this thing was way harder than I expected it to be.
aaron8
Re: Need New Engine
« Reply #3 on: May 23, 2017, 06:03:07 PM »
had a customers SXS do the same thing. hard abuse and it cracked the case around the bevel gear. you have to replace the case halves in a pair, im thinking the case was around $500
