Author Topic: top speed question  (Read 799 times)
houg
top speed question
« on: May 20, 2017, 04:05:30 PM »
i have a 2002 cobra racer it has a 70cc big bore kit, 94 main jet, tecnigas pipe derestricted cdi and variator , it has the stock air box with restrictor removed, the spark plug is a greyish all most tanish color at full throttle the engine buries the tac needle it pulls me uphill no problem at all ( i weigh 237lbs )   but my top speed gps is only 45mph   my question is with this set up shouldnt i be hitting at least 50mph??  im not sure if my rollers are stock or not, i tried the dr pulley flat rollers 6.5 gram and then the 9.5 gram either did any good so i put the stock ones back in
Snorvey
Re: top speed question
« Reply #1 on: May 20, 2017, 05:28:14 PM »
If it buries the revcounter needle then it sounds like it's undergeared. On motorcycles*, that translates to more teeth on the front sprocket and/or less teeth on the rear. At the end of the day though, it's all about experimenting and compromising. Upping the gearing might mean a higher top speed, but you'll likely find it slower to accelerate and less happy climbing hills.
*I don't know how this translates to scooter rollers and weights and stuff. Sorry.
houg
« Reply #2 on: May 20, 2017, 07:56:11 PM »
well it climbs hills like a pissed off badger so i guess if i gain top speed like u say then ill loose it on the bottom end witch i dont want too
GLV55
« Reply #3 on: May 20, 2017, 09:39:03 PM »
well it climbs hills like a pissed off badger...
Ha Ha Ha! I love that description - I'm going to use it, often! Thanks for the laugh.  ;D
2014 Lance PCH 150
2007 Kymco People 150 (totaled by a drunk, Oct. 2013)
Nampa, ID
MJR
« Reply #4 on: May 21, 2017, 12:13:41 AM »
That reminds me.
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
Mr. Paul
« Reply #5 on: May 21, 2017, 01:14:42 AM »
Badgers? We dont need no stinking Badgers!!  ;D ;D ;D
2009 Kymco People 150
1993 Honda Helix
Redk
« Reply #6 on: May 21, 2017, 04:33:55 AM »
The Cobra of the Sierra Madre, no doubt.
redk
« Reply #7 on: May 21, 2017, 01:51:42 PM »
my experience with motorcycles is that gearing doesn't have as much to do with top speed as horsepower,  for instance, my SV650 could go faster in 5th gear than it could in 6th.  RPM in 6th gear was not cranking enuf horsepower to overcome aerodynamics. I could actually go 3-4mph in the lower gear, not sure if this comes into play so much with a scooter,
