Author Topic: Carb question  (Read 653 times)
houg
Carb question
« on: May 21, 2017, 10:56:09 PM »
On my 2002 cobra racer in the carb throat there are three holes in the bottom one at  4oclock one at 6oclock and one at  8oclock. When I shut the engine off gas starts running out the 6oclock hole ( the bottom one ). Do I have a bad float inlet needle?????
MJR
Re: Carb question
« Reply #1 on: May 21, 2017, 11:46:09 PM »
Oh my, sorry couldn't resist.  :o
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
Mr. Paul
Re: Carb question
« Reply #2 on: May 22, 2017, 01:01:22 AM »
Truly laughing out loud! I hate it when that happens (My wife does)   Houg, the 6 o'clock hole fuel flow is controlled by your low idle screw adjuster. I cannot help beyond that. Hope you get it worked out.
« Last Edit: May 22, 2017, 01:05:15 AM by Mr. Paul »
2009 Kymco People 150
1993 Honda Helix
houg
Re: Carb question
« Reply #3 on: May 23, 2017, 01:13:57 PM »
it was the float level apparently the last owner like to tinker with it, the carb bowl was filling up wayyy tooo much, so after adjusting the float it doesnt leak out the 6oclock hole  ( no more drippys )  ;D ;D
Redk
Re: Carb question
« Reply #4 on: May 23, 2017, 03:58:49 PM »
it was the float level apparently the last owner like to tinker with it...
Yep.
It is a manageable adjustment, and should be effective for many thousands of miles.
Unqualified tinkering, in my experience, has brought an inglorious end to many small motorcycles and scooters.
Any flaws inherent in carburetion can be resolved with over-engineered fuel injection systems beyond the scope of home repair.
Glad you got it repaired !
redk
MJR
Re: Carb question
« Reply #5 on: May 24, 2017, 05:19:21 PM »
Yep.
I especially love it when a fuel injected vehicle owner removes the pressed in metal cap covering the minimum air flow screw on a throttle body so they can adjust it to compensate for a problem they can't or are unwilling to fix properly like it's an old fashioned idle adjustment screw.
Redk
Re: Carb question
« Reply #6 on: May 25, 2017, 06:11:51 PM »
I especially love it...
Online forums, such as this one, are a Wonderful thing !
Helpful owners have probably saved many, many scooters from the dump.
redk
