hello westcoast, did you say whether your Super 9 was LC or AC? These scooters are super fun to tweak to run better with pipe, jetting, CVT tuning, etc. However, I agree with Tries, it's probably never going to pull up hills like you want without 70cc kit.
You adjust the oil pump with cable length. There is an adjustment for the cable in front of the pump. Be careful not to have the cable bottom out at full throttle, or you will eventually pull the cable stop off the end of the cable, then you will be running without oil. Good luck
