It will be interesting to see how much extra power this engine can put out. it is already the highest 250cc vtwin out there the last time i checked.
you will need to open up the airbox some how to go up on idle jet, but the main jet is a easy fix, just lift out the baffles by 2 cm will give you the sound plus the near open exhaust to run larger main jets!
Good luck!
