Author Topic: Using tow straps to mount tires  (Read 578 times)
hypophthalmus
« on: May 26, 2017, 07:55:12 PM »
When I was changing my front tire, I found it helpful to use tow straps to hold the tire in the center well once you run out of slack. 2-3 tow straps on 1/3 of the tire seems to do it.
I went straight for this method with my rear tire and it was so much easier.
Re: Using tow straps to mount tires
« Reply #1 on: May 26, 2017, 11:00:04 PM »
I am dense:  how does this work? Got pictures?
Redk
« Reply #2 on: May 26, 2017, 11:13:09 PM »
When mounting some tubeless tires I've found it helpful to tie a rope/ cinch a strap around the centerline of the tire tread, then tighten it, as needed with a metal bar, as a windlass. This will help forced the bead against the rim, and help it seal quicker.
redk
Oh !  Almost forgot !
It's almost Always better to work with a warm tire.
Set it out in direct sun for 1/2 an hour or so before messing with it.
It makes a difference.
Yes, I use a wire wheel, wire brush, and/or sandpaper to assure the rim is clean and free of stuck debris beforehand, and have some soapy water applied to the tire bead with a rag.
hypophthalmus
« Reply #3 on: May 27, 2017, 12:05:25 AM »
I didn't have the foresight to take pictures, but here's a crudely drawn diagram:
http://earthwoodjoinery.com/random/photo/scooter/towstraptiremount.jpg
