Author Topic: 2007 kymco agility 50 big bore kit question  (Read 1413 times)
Jay89
« on: May 31, 2017, 03:17:15 AM »
Hi my name is Justin and I'm new to the scooter life..
I have a few quick questions about big bore kits what ones
can I use and what benefits do they bring?
And while I'm at at it type of engines do these scooters have?
Just looking to know for future part buying.
« Last Edit: May 31, 2017, 03:18:56 AM by Jay89 »
ThehardcoreFTW
  • Verstand op nul, blik op oneindig
Re: 2007 kymco agility 50 big bore kit question
« Reply #1 on: May 31, 2017, 10:11:10 AM »
Any part that`s listed as `GY6` or `139QMB` will fit. The code on your kymco block is different but it`s a 1:1 fit with any GY6 block with only the attachment points (to the frame) being different.
A big bore kit will increase your CC`s and therefore increase torque and hp (top speed will be the same because you will hit your rev limiter).
Downsides can include:
High potential for crank damage/wear
Higher fuel consumption
It`s not legal
Can go wrong, can deliver some issues (most of the time it`s not the parts fault though.)
Jay89
« Reply #2 on: May 31, 2017, 04:34:25 PM »
Thanks for the information I appreciate it.
I could only find one code it said kymco LDC8
Jay89
« Reply #3 on: May 31, 2017, 04:54:24 PM »
Found it just to double check my code is kg10sa 2200776
ThehardcoreFTW
« Reply #4 on: May 31, 2017, 05:33:18 PM »
That`s the correct code. kg10sa.
Jay89
« Reply #5 on: May 31, 2017, 09:56:26 PM »
Thank you for all you're help
