Author Topic: Where to take out rpm signal on Agility 200i or similar scooter  (Read 1015 times)
MartyMcFly
Hi all
I'm thinking about making an rpm counter for my Agility 200, but not sure where to get the tacho signal on such a motor (haven't looked at wiring yet, didn't receive manual yet).
Does anyone know if there's such a signal available from the motor?
For reference, I made one for my old Dax clone as you can see in my video here:
hypophthalmus
Re: Where to take out rpm signal on Agility 200i or similar scooter
« Reply #1 on: May 31, 2017, 01:38:46 PM »
The cheap tachometer I have for setting the idle speed uses a wire that wraps around the spark plug wire. It uses induction to get a reading.
No idea if that's actually helpful.
« Last Edit: May 31, 2017, 01:41:01 PM by hypophthalmus »
« Reply #2 on: May 31, 2017, 02:35:07 PM »
GREAT SCOTT, Marty! You have done a genious thing with that tach! Hypo is right with the induction idea since the spark discharge is rf or radio frequency even if it is fairly low frequency. Making a pick-up coil should be fairly simple like a few turns around the plug wire, each end connected to your circuit.
MartyMcFly
« Reply #3 on: May 31, 2017, 08:44:54 PM »
Thanks for the replies :)
The wire around the spark plug sounds like a good idea, I'll try it. I just hope the input is high enough impedance.
This rpm-thingy is really just an arduino board with some regulation circuitry and LEDs attached. I sold the Dax but still have the prototype - It might work as is with just the wire :)
Could be nice to have an idea about the revs the motor does.
« Reply #4 on: May 31, 2017, 08:51:16 PM »
You may have to ground the end of the wire not connected to your tach to get the signal but try it ungrounded first.
hypophthalmus
« Reply #5 on: June 02, 2017, 09:04:38 PM »
If you're willing to release plans of what you come up with, I'd be very interested in trying to duplicate it.
« Reply #6 on: June 13, 2017, 01:03:44 AM »
I used a tiny-tach (amazon) with wire wrapped on the plug lead -- seen in photos here....
http://www.kymcoforum.com/index.php?topic=10525.msg107937#msg107937
Two-sided 3-M auto-body foam taped the tach to the body....has been on there for 3 or 4 yrs with no issues. Works fine & records engine hours and most recent ride's high rpm reading.
I positioned it out of direct line of sight - I have found that there is NO time to be looking at the dash for any reason when urban riding! Out on the open road I might give it and the speedo a glance.
