Author Topic: Newly Acquired Kymco MXU 250  (Read 869 times)
polaraman
« on: June 04, 2017, 03:23:40 AM »
Hello All!
I recently acquired an MXU 250.  I was visiting my cousin in AL and saw his neighbor had a four wheeler under the shed that appeared to be sitting for awhile.  I ended up buying it without hearing it run.  Last week I ended up doing some troubleshooting and it appears that the starter is constantly engaged.   As soon as i put the battery cable on, the starter is trying to engage.  In my troubleshooting, I completely removed the starter solenoid and it's STILL trying to engage.
Does that mean I have a bad starter?
MJR
Re: Newly Acquired Kymco MXU 250
« Reply #1 on: June 04, 2017, 04:28:33 AM »
Certainly sounds like the attached solenoid is stuck.
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
polaraman
« Reply #2 on: June 05, 2017, 01:28:30 AM »
I replaced the solenoid with a known good solenoid and it still tries to crank.  I completely removed the solenoid and it still tries to crank.  What else could it be?
MJR
« Reply #3 on: June 05, 2017, 01:36:11 AM »
Disconnect the wire to the starter and isolate it, reconnect the battery and see if the solenoid clicks on. You may have power staying on from the starter button.
polaraman
« Reply #4 on: June 05, 2017, 12:11:58 PM »
Good idea!   I never thought of that.  Should i hear an audible click from the solenoid if/when the solenoid engages?
MJR
« Reply #5 on: June 05, 2017, 02:56:16 PM »
Possibly but a simple test light is great to have as well.
Redk
polaraman
« Reply #7 on: June 21, 2017, 12:31:03 PM »
Polaraman ???
https://www.hemmings.com/magazine/mus/2007/05/1969-Dodge-Polara-CHP/1451907.html
redk
You are correct.  The first car I ever bought was a 1963 Dodge Polara....   :)
