Author Topic: New tires  (Read 3572 times)
jdub0813
New tires
« on: June 12, 2017, 02:14:15 AM »
Well my used 2014 700i I noticed the side wall on my rear was patched on the sidewall and is leaking. Also front right is worn really bad. Thinking all new tires I guess which sucks as the other two are fine.
They are maxxis and I can't find the same ones so I can't just replace the two so looks like I'll just replace them all.
Any suggestions? I don't want to pay too much.
« Last Edit: June 12, 2017, 10:24:41 AM by jdub0813 »
Re: New tires
« Reply #1 on: June 13, 2017, 12:07:39 PM »
I found good prices on SunF tires both on e-bay & amazon, they have several different tire patterns, I got this set of street tread for $255 shipped,  every other street tread tire was at least 75% more
« Last Edit: June 13, 2017, 09:08:21 PM by randyo »
jdub0813
Re: New tires
« Reply #2 on: June 13, 2017, 01:25:38 PM »
Yeah thanks, I just went with the same brand SunF and got the All Terrain for 245 out the door.  Bought a tire changer from harbor freight so looking to do it myself.  Haven't done it yet but I feel confident lol.
airshot
Re: New tires
« Reply #3 on: June 13, 2017, 07:35:25 PM »
    Good looking tread pattern on those offroad tires, are they 6ply?  What about the weight of the tires? The big horn impressed me as they were the lightest weight 6 ply tire out there. But if only a couple pounds than that wouldn't mean much.
jdub0813
Re: New tires
« Reply #4 on: June 13, 2017, 07:38:59 PM »
Thank you, yeah I thought they looked alright for what I will be using them for.  They are 6 ply but I am not sure about the weight.  Shipment weight for all 4 is 40lbs haha but I know that doesn't help you out much.  Here are the specs listed.
Specifications:
Position: Front
PLY: 6
Tread Depth(mm/in):21.00/0.83
MAX P.S.I: 28
Standard Rim:12''x 6.5''
Load:638 lbs
Position: Rear
PLY: 6
MAX P.S.I: 28
Standard Rim:12''x 8''
Load:737 lbs
Re: New tires
« Reply #5 on: June 18, 2017, 07:12:15 PM »
my  new tires are much quieter and smoother on the road, they also handle the corners much better on pavement
jdub0813
Re: New tires
« Reply #6 on: June 21, 2017, 03:57:51 PM »
Looks good!  I just got mine done yesterday, much better.  Sucks one of the rubber covers for the axle nut is missing.  Probably damn near impossible to find one.
Re: New tires
« Reply #7 on: June 21, 2017, 05:00:15 PM »
I still have the rubber covers, but the centers of the Yamaha wheels are smaller diameter and do not fit on the wheels that are currently on my 450i
jdub0813
Re: New tires
« Reply #8 on: June 22, 2017, 04:55:53 PM »
I'll buy them from ya! Lol.
jdub0813
Re: New tires
« Reply #9 on: June 29, 2017, 10:12:37 PM »
So already have pickers stuck in my tire... slow leak in another... seriously so easy and they get punctured. 6 ply I need like 20... what tire pressure does everyone use?
Sent from my SM-G950U using Tapatalk
jdub0813
Re: New tires
« Reply #10 on: June 29, 2017, 11:08:55 PM »
Thorns I should say
airshot
Re: New tires
« Reply #11 on: June 30, 2017, 12:38:18 AM »
Should be easy to order one thru any dealer, check the Kymco website for a parts listing and give that number to the dealer for ordering. I have done that with no issue, and they also tell you what the part sells for so the dealer can't rip you off.  Now for the tires....punctured by a thorn?  Do you have really big thorns?  Is the 6 ply on the tread only?  What about the side wall?  Where was your puncture?  Sorry for so many questions but will be looking at tires for mine soon.
jdub0813
Re: New tires
« Reply #12 on: June 30, 2017, 01:14:36 AM »
Yeah pretty decent size thorns. And they are 6 ply, punctured in both tread and tire itself. Nothing in the sidewall I could see.  Ice tires but that seems a bit crazy to have thorns give me a flat but as others tell me that's common I guess it might be and I shouldn't be going far off the path like that
jdub0813
Re: New tires
« Reply #13 on: June 30, 2017, 04:12:38 PM »
But just wondering what pressure everyone runs?  Manual says 10 front and 14 back.  I usually go by manual as I read when I owned motorcycles that you should go by manual not by tire.  Seems strange as you might change tire and size so things would differ?  For these ATV wheels I wonder if 10 and 14 and too much... maybe do a 10 - 12 or something?
kickstart
Re: New tires
« Reply #14 on: July 01, 2017, 06:38:49 PM »
Nice looking Tires.
Who did you get the tires from?
