Author Topic: 2014 Kymco UXV 500i Wont Rev past 4k  (Read 1623 times)
justinba454
« on: June 19, 2017, 10:34:38 PM »
Is there a rev limiter that could be on the fritz? Saw something suggesting that the cdi box controls it? Any ideas would be appreciated. Drained gas thinking water in gas. Checked plug and air filters..
airshot
Re: 2014 Kymco UXV 500i Wont Rev past 4k
« Reply #1 on: June 20, 2017, 01:43:07 AM »
    To the best of my knowledge they all have a rev limiter, but is it the limiter kicking in of are you having a miss. When the rev limiter kicks in the engine just stops making rpm, sort of feels like a miss as the ignition keeps turning on and off. If the engine itself was missing due to other problem it would probably backfire at some point. I haven't had any issues with my 450i so I haven't done any trouble shooting yet. Has the engine revved above 4 thou in the past?  Not sure what your rpm specs are on that machine but it might well be brain box on the ignition. Hopefully someone with first hand knowledge will jump in here and help you out..There is also a help/service number at the factory you can call and mabey get some help there. I belong to "cyclepedia" online and they have a trouble shooting service there along with a full factory service manual. For 55 bucks for a lifetime membership it is well worth it!!
justinba454
« Reply #2 on: June 20, 2017, 03:43:15 PM »
Seems it used to rev up a lot harder than now
k9bitten
« Reply #3 on: June 25, 2017, 02:36:01 AM »
Valves adjusted correctly? Especially intake. Spec is 0.004" intake 0.007 exhaust.
Sent from my LGL52VL using Tapatalk
