Author Topic: What main jet to use with 72cc and other tips with 72cc  (Read 896 times)
InSaneSmc
« on: June 20, 2017, 01:16:50 AM »
What main jet to use with 72cc and should i replace the variator boss with the unrestricted one? Does this help it go uphill better and with 2 people on it
agoncalvesjr89
Re: What main jet to use with 72cc and other tips with 72cc
« Reply #1 on: October 11, 2017, 05:23:53 PM »
my Friend,,, if you swapped that WHOLE motor out with a 250cc engine... BUt still had that drive boss you still wouldnt get past 35mph. Despite the speed of your spinning variator,, if it cannot close past a certain point you will never go faster.
2013 SUPER8 2T 50
70cc MALOSSI KIT
STOCK CARB MAIN JET AT 98 , STOCK AIR BOX SNORKEL REMOVED.
NARAKU VARIATOR 6 GRAMS SLIDER / ROLLER COMB.
TECNIGAS NEXT R EXHAUST
SLIGHTLY LONGER THAN STOCK GATES DRIVE BELT.
TOP SPEED 50ISH , TONS OF POWER. 45MPH CRUISING
