Author Topic: MXU 250 troubleshooting and parts  (Read 330 times)
polaraman
« on: June 21, 2017, 12:39:08 PM »
Hey All,
I took some more time the last few weeks and I think I've found all the bugs with my newly acquired MXU 250.  I just need some help with parts and possibly tips on what i'm facing.
Cranking:   My starter is engaged all the time.  I completely removed the solenoid and the starter is still engaging.   What I done in the meantime is put a push button starter on the battery wire and it works temporarily.   With that said, I'm pretty sure I have a bad starter.   I double checked the starter button and it's free and clear of debris.  Do you guys recommend the starters on Ebay?
Safety switch:   Once I crank the engine and try to engage the transmission, it sometimes try to kill the motor when i put it in gear.   I have the foot brake down and the hand brake depressed and it still dies.  But then sometimes, it goes in gear with no issues.  Is there a safety switch I can check?
Bushings:  I noticed that when i'm decelerating, the back end of the ATV is very loose.   I looked and it seems like the bushings are gone.  Where could i find replacement bushings?
Other parts:   I need to replace the front brake pads and air cleaner too.  Could I source those from Ebay too or is there a recommended vendor?
Thanks in advance!
Polaraman
