Author Topic: K-Pipe 125 Chain and Sprockets  (Read 2462 times)
lilzip24
« on: June 21, 2017, 01:29:42 PM »
For those of you who added a tooth to the front sprocket, where did you purchase your new chain and sprocket from? E-bay seems to be all over the place
2016 Kymco K-Pipe 125
2014 Suzuki DL1000A VStrom
2007 Suzuki VL800C C50
h2ou8n4
Re: K-Pipe 125 Chain and Sprockets
« Reply #1 on: June 21, 2017, 04:36:55 PM »
If you have just a few miles on the bike, you may not need to replace the chain and rear sprocket...going up 1 tooth on the front...usually just let out the adjusters a bit.
When you're feeling mighty low
like your better days are past
Just take a ride in your underwear
and you'll feel better fast!
lilzip24
« Reply #2 on: June 22, 2017, 04:10:58 PM »
Usually yes you are correct, but in the other K-Pipe thread a couple of the guys stated they needed a longer chain
vwgti303
« Reply #3 on: June 26, 2017, 02:43:25 AM »
Here's a cheap sprocket on ebay that will work HERE. The chain does have to be 108 links. In ebay, just search "428 108 chain" that should do it. Plenty of cheap ones too.
« Last Edit: June 26, 2017, 02:45:51 AM by vwgti303 »
2016 Yamaha XSR900
2016 Kymco K-Pipe
