Author Topic: 2009 Kymco Xciting 500 RI Diary  (Read 2056 times)
tuxster
« on: June 24, 2017, 02:10:40 PM »
After about a couple of months of owning and using a motorbike for my daily needs, it dawned on me that a motorbike was not really a fit for my needs and style of riding.  So, finally took the dive to get my first maxi and traded in my motorbike for a 2009 Xciting 500.  I must say I'm loving the feel of the 500.  I believe this will be my ride for quite a while before I switch to a newer model.
As the 1st owner was an old bloke, and treated the 500 like a 50cc moped.  The 500 was not in a perfect state aesthetically, mechanically its sound aside from the non-working speedometer gauge and pulsing front brakes, it runs like a dream.  Not sure if the mileage is accurate though, it reads 22790 kms, but with a non-working odometer and speed gauge, who knows the exact mileage on this thing.
Now down to business in bringing her up to par with all of my previoud rides.  First order of busines is the speedometer.  I read up all I can of how the speedometer works on this thing and read up as much as I can and this SITE, helped me understand what Im dealing with.  With this knowledge, also read up on a topic, SPEEDOMTER PROBLEM, about this specific problem of non-working speedo on the xciting 500 and its quite a common problem.  Armed with a multitester, checked the continuity of the three wires of the speedo sensor.  Sure enough, the black wire was the culprit.  Had to splice open the sensor harness and find where the black wire broke off.  Within minutes, found the break in the line midway.  Soldered the break and installed the sensor and tested it...working speedometer done.
Now for the pulsing front brakes, my money was on a warped disc.  As I've checked and cleaned up the brake rotors and calipers, I notice a slight ding on the right caliper. The hit must be hard to knock the disc and warp it.  Jacked up the front end, removed the front fender and spun the wheel, and sure enough, the disc is bent, not much but enough for you to feel the pulse on the lever.  Will be ordering a disc as soon as budget permits.  For now, I did a temporary fix and tried to true the warped disc as much as I can without stressing it out and have the disc fail on me.  Did a good job, as the pulse was almost non-existent.  While I'm at it ordering the disc, might as well order a battery cover.  Found out just now that it did not have any as the first owner misplaced it.
Using the 500 now everyday for work and what not and weekend trips up the twistie backroads.  Now I noticed what these guys were talking about the speedometer being off by a lot, topic I read here 2007 Xciting 500 How to Recalibrate Speedometer?. Mine is off 10kph linear, at 60kph displayed I'm at 50, at 80kph I'm at 70, at 100 I'm at 90.  Did some digging and found this  https://www.jaycar.com.au/corrector-speedo-module/p/AA0376, it's basically a (SPEEDO HEALER) or (SPEEDDRD), but without the outrageous price tag.  Most of the guys here in Australia swears by it and have it installed it on their motorbikes with great success.
This will be at the top of my bucket list below the front disc rotors ofcourse.  Will update this thread as I progress to working out the quirks on my 500.
2009 Kymco Xciting 500Ri
2008 Honda CB400 Revo
2010 Kymco Like 50
2005 Aprilia SR50R
2003 Sym Jet Euro 100
2006 Yamaha Mio
2001 Sym Jet 100
1998 Kawasaki KMX125
1992 Suzuki RGV250
MJR
Re: 2009 Kymco Xciting 500 RI Diary
« Reply #1 on: June 24, 2017, 04:34:27 PM »
Nice to hear an older scoot getting the love.
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
tuxster
« Reply #2 on: June 25, 2017, 12:34:26 AM »
As they say, give it a little love and receive trouble free enjoyment in return.
A batch of T10 and T5 leds arrived together with led plate lights arrived.  Just installed them in to save on a few amps on the electrical system.  As Ive experienced first hand, this thing is hard to start in cold winter mornings.  Will be doing a Led headlight swap soon to save on more amps.
More in my todo list: change engine and gear oils, will be flushing the old brake fluid as soon as I replace the front rotors.  Will also be doing a cvt checkup soon as this this thing has not been opened up since new.
More to come.
2010 Kymco Like 50
2005 Aprilia SR50R
2006 Yamaha Mio
2001 Sym Jet 100
1992 Suzuki RGV250
MJR
« Reply #3 on: June 25, 2017, 06:43:38 AM »
Pictures, pictures please.  :)
tuxster
« Reply #4 on: June 25, 2017, 10:37:08 AM »
Will take a couple of snaps soon MJ...stay tuned. :)
2010 Kymco Like 50
2005 Aprilia SR50R
2006 Yamaha Mio
2001 Sym Jet 100
1992 Suzuki RGV250
Ricksride
« Reply #5 on: June 29, 2017, 02:10:45 AM »
I'm new on the forum as I joined to research all I can on the 500 xciting.
I'm looking at a 2007 (carb) model.
Just so happens the speedometer isn't working right. So reading this thread is really going to help if I buy that scoot.
It has some other things that will need attention. Nothing serious, though.
Again, it's almost like yours. Extremely low mileage, but runs perfectly. Looks... um... ah... let's just say I'm going to go through a few bottles of Black Restore.  :P
Scratches here and there but not from road rash. It's from drunks at a party that knocked it over. >:(
Rust on the bottom of the shocks, rear reflectors brackets, various screws that are exposed.
Me thinks it spent it's life outside, uncovered. ::)
If I do buy it, I will also have my own thread as a before and after with plenty of pictures.
sissymary
« Reply #6 on: June 29, 2017, 03:37:41 PM »
If you buy a carbed 2007, the first thing you should do is change the carbs diaphragm. If it does not have holes in it, it will have them very soon. If all of a sudden you can't get over 50MPH or so, that will be the culprit. :-*
Ricksride
« Reply #7 on: June 29, 2017, 05:44:44 PM »
Very good info. Being it's a Mikuni I'm guessing rebuild parts shouldn't be to hard to get?
