Author Topic: Wierd electrical problem  (Read 1492 times)
jeeves
  • Dubrovnik, Croatia
« on: June 27, 2017, 03:17:04 PM »
Last week my regulator/rectifier burned out and the main fuse burned out.
Today I received the r/r I ordered from eBay. It looks nearly the same as the original, all the right color wires in the right pins in the connector.
Put the battery back in , but as soon as I connect the r/r the scoot lights up without the key in the ignition! I tried to start it, it turns over but doesn't run.
I disconnected​ the r/r and then the scoot runs normal!
So is the r/r I bought a piece of crap, or do I have a bigger problem?
« Last Edit: June 27, 2017, 03:33:23 PM by jeeves »
Agility City 125
jeeves
Re: Wierd electrical problem
« Reply #1 on: June 27, 2017, 03:35:51 PM »
One thing comes to mind. The color of the wires going out of the r/r are in a different order then on the original. This doesn't necessarily mean it's wired wrong or does it?
Agility City 125
big blue
« Reply #2 on: June 30, 2017, 12:06:17 AM »
Kymco factory part?
Mr. Paul
« Reply #3 on: June 30, 2017, 12:15:59 AM »
If its not an original Kymco part, chances are its no good.
2009 Kymco People 150
1993 Honda Helix
jeeves
« Reply #4 on: June 30, 2017, 04:57:50 AM »
No, not original Kymco part, but the my model and production year are on his list of compatible scoots.
Contacted seller, he responded and said he will try to see if maybe the wires are connected  in a different order, but I somewhat doubt it, it's probably going back to him. Looks like OEM is the only way to go with Kymco.
Agility City 125
Mr. Paul
« Reply #5 on: June 30, 2017, 11:57:52 AM »
In my experience,  OEM is the best and cheapest way to go Jeeves.
1993 Honda Helix
« Reply #6 on: June 30, 2017, 01:41:00 PM »
Peter Kapitar in Hungary had his stator burned up by one of these after market reg/rect.
Mr. Paul
« Reply #7 on: June 30, 2017, 03:40:48 PM »
You are right Karl. In the long run cheap aftermarket parts cost far more than OEM in time and money.
1993 Honda Helix
jeeves
« Reply #8 on: June 30, 2017, 03:51:14 PM »
Seller contacted me today. Apparently it's a faulty run of r/r's from the manufacturer.
I'm sending it back, free postage and full refund.
Honest seller.
There were some language difficulties since I bought it on German ebay, but Google translate helped.
Ordered OEM.
Generic r/r was 44$ with shipping, OEM is gonna be 80$ without shipping.
OEM Kymco parts are waaaay too expensive.
« Last Edit: June 30, 2017, 04:42:55 PM by jeeves »
Agility City 125
Mr. Paul
« Reply #9 on: June 30, 2017, 05:45:50 PM »
I can't deny that OEM is expensive Jeeves. Unfortunately its the very best option. When you get it let us know how the OEM part works out for ya.
1993 Honda Helix
Redk
« Reply #10 on: July 02, 2017, 05:37:02 AM »
It's probably worth the extra money to know you will get a reliable part.
If that exists...
redk
jeeves
« Reply #11 on: July 03, 2017, 02:51:21 PM »
OEM r/r arrived today. Works ok.
The location of the r/r is probably the main reason that this is the second one I had to replace.
It is located underneath the floorboard with no venting whatsoever, and turned facing backwards!
Really stupid engineering to put a component that has passive cooling in such a place.
Have been thinking to extend the wires and try to place it somewhere above the headlight, but really need the scoot, and don't have time for that now.
The  r/r connector can be seen dangling under the floorboard.
« Last Edit: July 03, 2017, 02:56:55 PM by jeeves »
Agility City 125
