Author Topic: Use no anti seize on NGK plugs  (Read 1029 times)
« on: July 07, 2017, 08:14:44 PM »
Old habbits vs new technology.  There WAS a time when spark plugs seized in engines. I had a 60's Mustang convertible with one frozen plug. Broke 2 sockets and quit fooling with it. Small block V8.
 Reading an article on Rotax airplane engines today...I read again that NGK  says not to use any anti-seize products when installing their spark plugs. For at least two reasons - anti-seize pastes reduce friction when installing a spark plug - which often leads to overtightening and damaged cylinder threads. Also, most pastes are electrical conductors and can short a plug electrode. Importantly - also, NGK spark plugs are already coated against corrosion and seizing with a special finish.
There is a paste that is used on some NGK applications - but it is used to facilitate a specific heat transfer on certain aircooled light airplane engines.
Once again, NGK is very specific about using only the recommended spark plug for your engine.
Re: Use no anti seize on NGK plugs
« Reply #1 on: July 08, 2017, 12:17:35 AM »
You gotta be kiddin', sonny! Why, I been screwin' spark plugs into and outten Pratts since 'fore you even knew what an aileron was and we ALWAYS used anti-seize! Always been that way!
If NGK says don't use anti-seize they probably know what they are talking about and have developed the goods that work. That slippery stuff WILL make it easy to strip threads and it is NASTY to get on your hands! Doesthat apply to all NGK plugs? Thanks for the info!
MJR
« Reply #2 on: July 08, 2017, 03:53:48 AM »
Never used anti seize as a dealer mechanic, never had a problem getting them out, old (crush washer) or new (taper fit).
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
ole two wheels
  • ole two wheels
« Reply #3 on: July 08, 2017, 05:06:29 AM »
The use of anti seize, on spark plug threads, really caught on with the advent of aluminum heads. Steel and aluminum that go thru heat cycles together is never good, especially where threads are involved. The sale of heli coil kits also increased about that same time. The biggest problem occurs when some one dips the plug in anti-seize instead of just putting on a light coat. A little dab will do ya.
Mac
2012 Kymco DT300
1996 Honda Shadow Spirit 1100
Redk
« Reply #4 on: July 08, 2017, 06:30:36 AM »
I did read that NGK article Stig mentioned, quite some time ago.
NGK is demanding control of the plug temp and do not want anyone tampering with the fitment between the plug and the cylinder head with some sort of goop they may fancy ATM.
They couldn't be less interested if the machine is abused in some sort of Xtreme service and left for months or even years without proper service.
Neither do they care if threads are pulled when the plug is eventually ruined.
They would place blame on the mechanic or the manufacturer of the cylinder head.
I do know for fact that the silver colored anti-seize compound applied to nuts and bolts on under-sea mining equipment operated at 14,000ft depth remains effective and the equipment may be dis-assembled when retrieved.
I will continue to make use of it, as I have always done, and be cautious to use it sparingly so I don't affect those precious NGK's !
At the racer's edge, optimal ignition is right at the top of the list in the winner's circle.
Hmmm...  I never been there.
I'm not a racey kinda guy.
redk
mrbios
  • 2005 Kymco Grandvista 250cc
    • My YouTube Channel
« Reply #5 on: July 09, 2017, 09:29:01 AM »
I agree with crossbolt and RedkI always use anti-seize even on NGK plugs for my scoot.  I put a very small amount on.  I don't over-tighten spark plugs I just snug them.  No problems ever.
PaulC
boo
I will always use anti seize
« Reply #6 on: July 15, 2017, 01:26:39 PM »
On spark plugs. I have seen how plugs seize in aluminum heads. My brother in law has a Honda Civic that has one spark plug stuck in it and cannot get it out.
It would be very hard for me to NOT use anti seize.
300GTI black
Pro 2A - member GOA & NRA
