Author Topic: 2t redline  (Read 1099 times)
DennyB
2t redline
« on: July 10, 2017, 08:22:28 PM »
Hello all,
Any info on the rpm redline for a 2008 people 50 2 stroke?
Assuming stock engine internals.
Thanks,
Denny
chaz35
  • old guy
Re: 2t redline
« Reply #1 on: July 12, 2017, 01:47:18 PM »
what tach you using?  I used TrailTech TTO worked OK, cheap to buy.  I wouldn't worry about rpm, heat is the problem.  with stock engine, I ran mine wide open all the time, no issues.  with 70cc kit, would turn over 10,000, but always ran hot, never could get it figured out, finally decided air cooled engine couldn't take it, cooling fins not large enough area to keep engine cool.  cheers
DennyB
Re: 2t redline
« Reply #2 on: July 12, 2017, 08:23:56 PM »
I don't have a tach as of yet. Was pondering getting one as this scoot is pretty quick and winds up quickly. If RPM is not an issue I will not worry about it.
Thanks for the info!
Denny MacZippingalong
