Author Topic: The New LIKE150i - FRAME Details  (Read 1844 times)
« on: July 11, 2017, 01:16:27 AM »
Recent web find, translated:
The frame is reinforced with two pipes starting from the neck (downpipes), new transverse section in support of the engine and a different finish to the back. The objective is the greater rigidity and better drivability. In the same vein, the tank is positioned low and in front of the engine, so the stopped in front of the rider.
The fork is telescopic, single plate with rod diameter 33mm (not bad for a little scooter) and route 95mm. Rear suspension shock absorber with two path undertake 86mm and preload adjust spring in three positions.
The dimensions of the wheels are 110/70-12 and back 130/70-12.
Kymco-Like-125-150-my2017-frames
The left frame is Like new and old right. See dual downpipes and the new (red) traverse.
« Last Edit: July 11, 2017, 12:14:19 PM by Stig »
