Hello,
Not to get hopes wildly up - because my 4 yrs of experience with this LIKE200i is that these 're-sets' are not much more than superstitious in nature!
...but it can't hurt to try. You just might be the first to get the healing! Seriously - it can't hurt to give it a go.
This re-set is done if some stuff has been removed and reinstalled - (MAP, ISC, TPS or ECU) - or you just want to be sure:In the battery box is a pink wire, probably. (some LIKE's may not have this )
1)Turn the key to the 'ON' position (do not start the scooter)
2) ground the pink wire to the negative battery post - or to a scooter 'ground' - the frame.
3) turn the key off, then remove the pink wire from the ground/battery post (above)
Another re-set for the TPS:1) Turn on and off key (no start!) three times - each function (on & off) is held for at least 4 seconds.
"on 4+ seconds, off 4+ seconds, on 4+ seconds, off 4+ seconds, on 4+ seconds, off 4+ seconds - have a coffee"
Self-diagnostic Re-set:1) Turn key on (no start!) and wait 10 seconds
2) Fully open throttle and hold for 10 seconds
3) Fully close throttle
4) After 5 seconds the light will blink twice
5) Key off, finish coffee.
My LIKE200i was 11 months old when I bought it. I think
many of our LIKE's were purchased many months from their production date in China. They still ran fine. (there's a silver sticker under the right side skirt - visible with a torch)
At 950 miles - PSI in tires, Air filter (incl. foam cover) and that snorkel (w or w/o the reducer) are not your performance problem. There is a trouble shoot mention in serv. manual of a possible pinched fuel tank breather and clogged muffler. Both easy to check..
Main items in trouble shoot for poor high speed performance are;
#1 ECU
#2 fuel pressure regulator
#3 fuel injector .... so maybe some Techron ? (but would that cause low mpg's ? doubt it)
If your brakes are not dragging, Thinking you need the diagnostic meter put on the scoot....in case it is simply a faulty ECU - which no DIY could ever find and fix without replacing the unit.
good luck
PS: yeah, scooters make all kinds of weird unmotorcycle-like noises. I just sing louder.
