Author Topic: 450i tire pressure?  (Read 1981 times)
dlongo
450i tire pressure?
« on: July 20, 2017, 02:10:27 AM »
 Hey guys what are you running in the front and rear tires on your 450i?
jdub0813
Re: 450i tire pressure?
« Reply #1 on: July 20, 2017, 10:18:45 AM »
My 700i manual says 14 rear 12 front... seems a bit much so I'm testing 11 rear 9 front. How about you?
« Reply #2 on: July 20, 2017, 03:52:10 PM »
I run 18 all the way around on the street (20 in back if I'm towing my backhoe), drop it to 12 front/16 rear for off road, usually the bed has at least 200 lbs of equipment (chain saw, fuel, oil, peavy, choker chain, block & tackle, tool box with a small floor jack & assorted tools  etc.
I am almost always at the limits of capacity or overloaded
airshot
« Reply #3 on: July 20, 2017, 04:59:04 PM »
   Normally not carrying weight so at factory specs or slightly below (1-2lbs less). If I am going to add any weight then make sure I am at factory specs. This is with the stock Maxxis tires, will have to refigure pressures when I move to 26" tires.
jdub0813
« Reply #4 on: July 20, 2017, 07:45:53 PM »
That seems like a lot for ATV/UTV tires.  14psi which is factory spec seems like quite a bit and my tires say max 14.  So I dropped it a bit.  Probably should add a little more to it.  Maybe do 10-12
