Author Topic: Agility 50 fuel valve  (Read 2233 times)
Gthartiii
« on: July 21, 2017, 09:12:24 PM »
Having problem with fuel to carb
Sat 1 year so expected issues
Engine starts runs 10 secs and cuts out
Decided I should have drained gas so decided to replace fuel filter while I was at it
Figured I would just drain gas into can when I disconnected fuel line from filter
I have half a tank and already replaced spark plug
When I disconnect fuel line from filter no gas drains out at all
Does that mean the fuel valve is bad?
There is nothing else between tank and hose but that
Gthartiii
Re: Agility 50 fuel valve
« Reply #1 on: July 21, 2017, 09:25:53 PM »
Never mind
Wrong forum and I figured it out
Vacuum line has to open the valve
I can't delete this so I will leave it at that
