Author Topic: Bracket for the back fender?  (Read 506 times)
Nireen
« on: July 24, 2017, 10:54:54 AM »
The bracket that holds the rear fender to the bike cracked in two!  suggestions to fix or replace?
Kat :)
Re: Bracket for the back fender?
« Reply #1 on: July 24, 2017, 11:49:41 AM »
Remove and weld, use for pattern to make a replacement out of heavier stuff. Re-install repaired bracket while replacement is made, r & r when original breaks again. Post the morning after. You been ridin' a lot of gravel roads?
Nireen
« Reply #2 on: July 24, 2017, 01:43:40 PM »
Hey Karl thanks :) No Kat does no gravel roads!  But some of the roads in PEI are ruff.  I think it was on to snug to start with and the pressure broke it???
Kat :)
