Author Topic: Burping coolant with the radiator not full?  (Read 725 times)
hypophthalmus
« on: August 01, 2017, 05:03:05 PM »
A problem I've had with burping the coolant system is carefully avoiding having the level rise above the neck and spilling coolant everywhere.
I came across a suggestion that seems obvious in retrospect, which is to burp the system with the radiator 1/2 full.
There wouldn't be any problems with that, right?
Re: Burping coolant with the radiator not full?
« Reply #1 on: August 01, 2017, 07:10:26 PM »
Nope!
Mr. Paul
« Reply #2 on: August 01, 2017, 09:35:05 PM »
Why didnt I think of that? :-[
2009 Kymco People 150
1993 Honda Helix
MJR
« Reply #3 on: August 02, 2017, 12:38:51 AM »
I think I need to make an extension for my fancy coolant funnel.
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
Mr. Paul
« Reply #4 on: August 03, 2017, 12:29:57 AM »
Its missing a flux capacitor!
1993 Honda Helix
DakLak
« Reply #5 on: August 11, 2017, 02:21:11 AM »
Am aged mechanic I knew who maintained large, stationary, emergency generators always topped up his radiators with boiled water.
Boiled water is 'flat' - all the natural air has been boiled off - and avoids 'burping'.
Never, ever, try to open any radiator that is too hot to hold with a hand. Water, under pressure, holds air. When you remove the filler cap, the absorbed air will come out of the water and try to escape - squirting wet air and water over your face.
Draping a rag over a cap when opening will catch all the emitted water.
