Author Topic: Mxu 270 question  (Read 331 times)
Iam4iu1970
Mxu 270 question
« on: August 10, 2017, 08:46:36 PM »
I just bought a new 2017 mxu 270 it said on the kymco that it goes 38 mph but I've taken the speed limiter out as far as it goes without unscrewing the whole thing and it still only goes 29 mph. Does anyone know how to fix so it goes faster. I saw a YouTube where someone unplugged the cdi plug and looks like it ran faster is  this something I could do without hurting or messing mine up.
Thanks
souzamoto
Re: Mxu 270 question
« Reply #1 on: August 10, 2017, 11:15:12 PM »
DO NOT run your 270 with the throttle stop backed out in stock form. It will over-rev and over-heat and you will have major issues.
Kymco did the restrictions so that the ATV would be legal for a 14 year old to ride. The restriction is in the CVT.
If you are an adult, 16 or older, you can change the CVT Variator Shaft to the one used in a MXU300. The part number is:
22105-LBA7-900 from any Kymco dealer. They are about $27.00.
If you don't know what you are doing mechanically, I would have the dealer install the part. Then you can run it with the throttle stop backed out all the way and go way fast.
Don't mess with the CDI, there is nothing to mess with.
Change the shaft and you will be happy.
CJS
Iam4iu1970
« Reply #2 on: August 11, 2017, 08:25:03 PM »
Thank you so much CJS. After this is installed do you take the speed limitor screw out or leave it in.
