Author Topic: Has anyone ever fitted a bigger bore cylinder kit to an Agility 125?  (Read 4826 times)
118118
As the title say, I'm very interested to hear from anyone who has actually fitted a big bore kit to an Agility 125.
I'm interested to know if the crankcases had to be machined out to accept the larger diameter barrel.
I've been told by a supplier in the UK that the standard kymco crankcase opening is 57mm only.
Many thanks.
jeeves
  • Dubrovnik, Croatia
Re: Has anyone ever fitted a bigger bore cylinder kit to an Agility 125?
« Reply #1 on: August 16, 2017, 06:43:12 AM »
I'm not a mechanic, neither I have done this,but in a big bore kit you should get everything you need.
Bigger piston that connects to the original piston rod, piston rings, cylinder and gaskets. Don't see a reason to machine out anything.
http://www.ebay.co.uk/itm/272717407931
Agility City 125
msecanmo
« Reply #2 on: September 15, 2017, 03:56:24 PM »
I have agility, 125 R16. I've put the cylinder 160 on a no-load basis. The main dive # 110 and variomat sport top performance with weights of 13.5 grams.
118118
« Reply #3 on: September 17, 2017, 11:24:28 AM »
Ok Guys, I'm answering my own question.
Curiosity got the better of me, so I removed the engine and cylinder to measure the crankcase opening. It measured 60.7 mm. This allowed me to fit the 150cc cylinder kit I wanted. I purchased an Airsal kit from Pedparts in the UK. Great to deal with and fast delivery. The kits are cast and machined at the Airsal factory near Barcelona in Spain and are very good quality.
I've refitted the engine and it runs fine so Just got to refit the panels and seat and then its time to start running her in. It say the running in period is 45 - 55 minutes at half throttle the your good to go!  :)
« Last Edit: September 18, 2017, 09:53:59 AM by 118118 »
msecanmo
« Reply #4 on: September 17, 2017, 01:16:18 PM »
Super. Give us your observations. Did you replace the main jet.
« Last Edit: September 17, 2017, 01:19:40 PM by msecanmo »
118118
« Reply #5 on: September 17, 2017, 01:39:01 PM »
Yes, main jet changed from 104 to 110 to start with. We'll see how we go. I may even get her on the dyno as a friend runs an MX shop.
jeeves
« Reply #6 on: September 17, 2017, 02:00:41 PM »
Any reason why you didn't go up to 163ccm?
Agility City 125
msecanmo
« Reply #7 on: September 17, 2017, 06:31:59 PM »
The 160-cc kit has a diameter of 60.4mm so that it enters the crankshaft without any problems. I am overwhelmed. My final speed is 100 km / h. Accelerations are great, and consumption is about 4.2lit to 100km.
118118
« Reply #8 on: September 18, 2017, 08:13:30 AM »
As the title of this post says, I had a lack of information and no one seemed to be able to give me answers. A lot of the suppliers don't list cylinder skirt sizes and I didn't want to risk buying something that was to large to fit in my crankcase.
Secondly, I didn't want to have to upgrade the standard Carb & airbox. I wasn't sure what I could get away with.
I'm sure i'll be happy with the 150cc and it was a good little project to do.
« Last Edit: September 18, 2017, 08:17:06 AM by 118118 »
jeeves
« Reply #9 on: September 18, 2017, 02:44:40 PM »
[emoji106]
So how does it compare to the 125ccm?
How much did the fuel consumption go up?
Agility City 125
118118
« Reply #10 on: September 27, 2017, 10:46:41 AM »
[emoji106]
It is definitely a little more spritely when pulling off, just wants to go! I don't use the scooter regularly so its going to take some time to run her in. She easily sits at 50 mph (on my Garmin GPS) at 3/4 throttle.
As for fuel consumption, I never measured it before so I cant comment but the scooter is only a toy anyway.  ;)
msecanmo
« Reply #11 on: September 27, 2017, 07:25:20 PM »
Keep track of our observations. And it measures the consumption to compare with yours. ;)
scooterScotty
Re: Has anyone ever fitted a bigger bore cylinder kit to an Kymko People 150?
« Reply #12 on: February 27, 2019, 11:19:34 PM »
I am a new member too glad to Join you all,
Dang i hope peeps150 is correct and he actually did install a Bolt-on direct bolt on 61mm Cylinder kit which should be 170cc or 171cc, but i was told that my 2006 kymko people 150 is NOT same as GY6, so the NCY 61mm direct bolt on big-bore kit will Not work??-is this true, or can i get a blt on big bore kit for my 2006 kymko people 150 scooter???
another bummer is even if I can get my hands on the 61 mm direct bolt-on big-bore kits...rear end final drive Gears i am told are also diferent-wont fit???
Regarding-old post-Hello,
New member here.  I just traded my ps3 for a blown 2009 people 150.  I just put a 61mm big bore kit in it and she's finally running once again.  I also out a installed an aftermarket intake and muffler system.  For those who have aftermarket parts on their people 150, what size jets are you guys using? I have already tinkered with the carburetor as much as I can, I think she is still running lean on the 110 stock jet.
Heres my Cafe Scooter lol
[/quote]
scooterfan
« Reply #13 on: April 04, 2019, 07:39:57 AM »
Very interesting thread.
Fuel consumption seem to take quite a knock on an upgrade like this ?
 Fuel consumption on my Agility 125 (with more than 11 000 km on the clock and 13” wheels) is between 35 to 37 km / Liter.
Maybe it will be better to install a 14” wheel at the rear on an upgrade like this ?
Kymco Agility 125
Honda Silverwing 600
Suzuki Boulevard C50T
