Hey guys. I have a problem with the speedo on my 50X. When I got it used, the speedo didn't work. At least not the speed part. Replaced the sensor at the wheel and put a new speedo on it. It was obvious the previous owner screwed with it because the cover was held on by an elastic strap and corrosion could be seen inside on the motherboard. Everything was working fine then the speedo started only working intermittently now not at all. Still just the speed part. Gas gauge and turn signal parts all still work. My son is riding it so when I can get him over here I'll check all of the multiple connections that come from the speedo and make sure nothing wiggled loose but can anybody shed any light on this? Nothing else to replace since its only comprised of the sensor and the speedo and its all new. Thanks guys.
