Author Topic: Watercool converstion  (Read 1291 times)
Bermyboy135
« on: August 21, 2017, 04:53:31 AM »
just wonder if the kymco super 9 engine is the same as a kymc people 50cc in that the difference is the water pump in bottom half but I'm just wondering if the kymco super 9 block will bolt on to the kymco people engine??? I noticed the engine look alike.
Mr. Paul
Re: Watercool converstion
« Reply #1 on: August 25, 2017, 10:45:44 PM »
IMHO its not worth the trouble.
2009 Kymco People 150
1993 Honda Helix
chaz35
  • old guy
« Reply #2 on: September 02, 2017, 12:30:34 AM »
as I understand it, Super 9 LC engine is different engine than AC.  I haven't done it, but I understand not that hard to convert your AC engine to LC.  You get the LC 70cc kit and add an electric water pump and radiator.  I wouldn't do it, too much work for me, but many have.  Cheers
Dabby-D
« Reply #3 on: September 03, 2017, 06:52:37 AM »
Wonder if you could just keep the air cooling and get an external 12v waterpump and water cooled cylinder head. They are sometimes a bit more annoying to work on then air cooled, I wont lie. I have had to learn to tune as i go for the first time build and only have a few more parts til i max out my performance and am not currently running due to problems. coolants expensive too.
2005 Super 9 LC - Airsal (T6) 73.8cc BBK
Battery: Chromes-Pro I-gel w/ self tester & LCD
Stator:(soon) Artek K2 rotor w/light
cooling:(soon) Bosh 12v water pump
Carb: 19mm PHGB (soon)Yoshimura 24
Air filter: Malossi E5 chrome
Variator: Malossi - Clutch: Malossi MHR Delta
Exhaust: technigas Next-R
