Hi all.
Things have been going well for almost a year, since an exhaust cam job.
But....
Yesturday I found a tan coloured milky sticky mess, with green drops in it(the colour of my coolant).
This was found under the left front part of the engine while parked on the side stand.
I had noted that the scoot was idling a bit rougher than before for a few days, and starting required a few turns of the key.
THE MAIN QUESTION : So, what do you think is the damage?
Since it does look like I will need some mechanical work, I will also get a high oil consumption problem sorted at the same time. I change my oil and filter every 3000km,and need an extra 1L for topups between changes.
