Author Topic: Charging system output  (Read 976 times)
« on: August 30, 2017, 01:54:06 AM »
Anyone know the max output in amps of any Kymco charging system? Specifically for DT300i? Xciting series? This is connected to the "bright idea" posted elsewhere.
TLRam1
Re: Charging system output
« Reply #1 on: August 31, 2017, 05:41:15 AM »
I would like to know on the People S250.
Terry
10 Kymco People S 250
87 Yamaha Riva 200 (Sold)
Allen TX (Dallas)
cli-maxridinggear.com
MJR
« Reply #2 on: August 31, 2017, 04:22:52 PM »
The MyRoad 700i service manual says mine is rated at 300 watts/5,000 rpm.
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
« Reply #3 on: August 31, 2017, 05:51:47 PM »
P=EI where P is watts, E is volts and I is amps so I=P/I or 300/12= 25 amps. That is right for a 30 amp fuse in the charging circuit. That what is in your 700i?
MJR
« Reply #4 on: September 01, 2017, 03:33:41 PM »
Whereas the charging voltage is higher the available current gets reduced but yes the circuit is protected by a 30A fuse and shown in the manual.
« Reply #5 on: September 01, 2017, 03:58:46 PM »
Thanks, MJR, that confirms the charging systems are pretty consistent  among the models. Probably use the same parts since the rect-reg is the same part number for nearly all the 250, 300 cc and up. Since the 30 amp fuse seems not to blow with battery problems like shorted cells then some fusing between the alternator (stator) and the regulator would be in order. Or just replace the Kymco reg-rect before it destroys the stator.
