Author Topic: Hard start?  (Read 3963 times)
jdub0813
Hard start?
« on: August 31, 2017, 04:39:15 PM »
450/700 riders...
Has anyone had issues with starting?  I notice ever since I have had mine it doesn't fire up right away when it's cold.  I turn the key and wait for the EFI to kick off then turn the key to start and it tries to fire but doesn't right away.  Usually I will let off then turn it again then it will start.
Wondering if anyone has had this issue or know what might be causing it?  Maybe fuel filter or something with the EFI?
Re: Hard start?
« Reply #1 on: August 31, 2017, 08:20:05 PM »
Opinion: Kymco start systems are so marginal that when the temp drops the load of the starter slows crank speed and lowers effectiveness of the spark as well as the temp-pressure compensation from the ECU. Hard starts are common in the 500 and 700 cc scoots, too. Not so much in the 300 EFI models.
jdub0813
Re: Hard start?
« Reply #2 on: August 31, 2017, 08:22:07 PM »
Ahh okay, I appreciate the feedback.. Wasn't sure if it was something I should be worrying about, maybe the fuel pump going back.  But that makes me worry a little less.  I mean after a few seconds of turning it over it fires right up and when it's warm it starts immediately.  Thank you.
Re: Hard start?
« Reply #3 on: August 31, 2017, 08:26:54 PM »
???? my 450i has always started nearly immediately, even in the coldest weather (down to zero °f or below)
Re: Hard start?
« Reply #4 on: August 31, 2017, 08:35:24 PM »
My sxs UVX500i will roll up on compression and stop, Randy. I let it roll back and hit it again with the starter which rolls past TDC. Once past that first stops it spins and starts. More finesse needed in really cold weather. Guess we gotta move the "marginal" up past the 450i!
Macman
Re: Hard start?
« Reply #5 on: September 09, 2017, 07:47:48 PM »
450/700 riders...
Is the battery good?  Sounds like nothing to worry about, if it's cranking slow get a new / better battery.
jdub0813
Re: Hard start?
« Reply #6 on: September 14, 2017, 12:06:10 PM »
Battery is good, not slow cranking by any means.  Thinking it's just another little thing about the Kymco is all.  I tried some injector cleaner and sea foam but haven't really noticed a difference.  Maybe fuel pump is going or the fuel filter needs to be changed, or like I said just a Kymco thing.
poorboy1964
Re: Hard start?
« Reply #7 on: September 14, 2017, 02:05:32 PM »
Check fuel line make sure it's not pinched anywhere I had this problem it had popped out of a clip and the seat was pinching it off partially
mtbrbike
Re: Hard start?
« Reply #8 on: September 18, 2017, 05:59:30 PM »
Hello,
I have a 2015 UXV 700 and it has always been super hard to start in the cold.   I replaced the batter this spring and hope this will help but the starter is now going on it.  Is there a part number (cross reference with another brand) for this  UTV?
Also it now does not start in gear so I am assuming it can be blown fuse which I will start with.
Thanks
Macman
Re: Hard start?
« Reply #9 on: September 18, 2017, 07:54:53 PM »
Hello,
Thanks
Not starting in gear could be related to the brake switch.  If it's not seeing that the brake is applied it won't try and start
