Author Topic: wheel offset  (Read 986 times)
wheel offset
« on: September 05, 2017, 07:38:12 PM »
As I have posted before, most of the miles on my UXV450i are street miles, I bought a spare set of 12" wheels and a most street oriented tread, but they are still "off road" tires and DOT tires in 12" are rather expensive
been looking at 14"x7" wheels that I can buy regular car tires for and have found wheels with a 5+2 offset and 4+3 offset
I will be mounting 235/60R-14s, for $80/tire, I can get a tire with a 50,000 mile treadlife warranty
airshot
Re: wheel offset
« Reply #1 on: September 06, 2017, 02:50:59 AM »
    Be sure you check the OD of the tire, wouldn't want to see your gear ratio get to far out of whack with the equipment you tow. Could be really rough on drive belts if the tires are to tall.
Re: wheel offset
« Reply #2 on: September 06, 2017, 04:23:36 AM »
235/60-14 is theoretically 25.1" tall, as close to identical to stock size as you can get
poorboy1964
Re: wheel offset
« Reply #3 on: September 06, 2017, 02:04:37 PM »
and only 9.3 wide that should work very well for you. what tire are you going with?
airshot
Re: wheel offset
« Reply #4 on: September 06, 2017, 07:15:44 PM »
    Hopefully we will get a pic of these new street treads and wheels!!  With these new tires will you be able to run a higher air pressure similar to a car?
Re: wheel offset
« Reply #5 on: September 07, 2017, 06:30:42 PM »
for sure I will post pics if and when this happens
thoughts on offset ?
looks like stock front offset is 5+2 and rear 7+2
so If I go with the 4+3 offset, I would have a 2" wider wheel base, but would that be detrimental to bearing life, I would assume the stock offset puts the weight squarely on the wheel bearings, so a 4+3 would center the weight and inch outward from the wheel bearings
is this a big deal or not
airshot
Re: wheel offset
« Reply #6 on: September 08, 2017, 01:59:47 AM »
      If you are only one inch offset I don't see that as a big deal as you are not hauling heavy loads only towing heavy loads if I understand correctly. I would not want to go more than the inch if it were my machine. I like to ride and play but not work on them so I do whatever I can to keep work at a minimum.
