Author Topic: 2017 super 8 stops running while idling  (Read 1437 times)
LittleDalek
« on: September 12, 2017, 12:33:49 PM »
So I just got the scooter, and since it's been cooler here, I have to let her warm up in the morning.  So she'll be idling, but then any time I try use the throttle, she stops and I habe to let her sit before trying again and just have the same results. Help?
Re: 2017 super 8 stops running while idling
« Reply #1 on: September 12, 2017, 10:42:07 PM »
New machine, not running right, give the dealer a chance to get it right under warranty.
Tiny
  • Ontario, Canada
« Reply #2 on: September 28, 2017, 10:19:12 PM »
have the fuel lines checked. Had the same issue with my Movie and it turned out that the fuel line had a small blockage
Mr. Paul
« Reply #3 on: September 29, 2017, 12:40:01 AM »
2009 Kymco People 150
1993 Honda Helix
150scoots
« Reply #4 on: November 03, 2017, 11:03:54 PM »
I had the same problem...turns out the gas cap is not venting properly. I just remove gas cap and she starts up and usually stays running.
RickEEE
« Reply #5 on: November 21, 2017, 03:30:27 AM »
If under warranty, shop should fix. Had identical issue. Turned out to be a plugged slow jet. Replaced it and scoot runs like a million bucks!
erics
« Reply #6 on: December 04, 2017, 09:11:43 PM »
I just purchased my 2nd super 8 150 with the same problem.  This is a 2016 model. I have to work on it next weekend
