Author Topic: HOW TO SHUT OF THE OIL LIGHT?  (Read 1624 times)
Nireen
« on: September 12, 2017, 01:22:25 PM »
I want to shut of the oil light.  How to? :) THANKS!
Kat :)
kneeslider
Re: HOW TO SHUT OF THE OIL LIGHT?
« Reply #1 on: September 12, 2017, 01:50:24 PM »
Same as resetting the trip meter. But you do it when the display is the odometer.
Sent from my HUAWEI VNS-L31 using Tapatalk
2019 Yamaha X-Max 250
Nireen
« Reply #2 on: September 13, 2017, 07:53:03 AM »
Hmmm I never set trip meter :/
Kat :)
« Reply #3 on: September 13, 2017, 06:47:19 PM »
A trip meter,   B trip meter,   oil change meter   hold outside buttons till it resets,.    right button to change from a   to b   to oil change   to odometer
Snorvey
« Reply #4 on: September 13, 2017, 07:37:24 PM »
Alternatively, take a one inch square piece of black electrical insulating tape and stick over offending warning light and.......voila! Problem solved.
« Reply #5 on: September 14, 2017, 03:34:15 AM »
  cant do that !  it is too easy,.
Nireen
« Reply #6 on: September 14, 2017, 06:31:25 AM »
I was gonna do that LOL!!!!!!!
Kat :)
Nireen
« Reply #7 on: September 14, 2017, 06:32:39 AM »
OK so have three buttons.  The two outside one's you mean?  Hold until what?
Kat :)
Nireen
« Reply #8 on: September 14, 2017, 07:47:24 AM »
Kat got it! :D thanks everyone ♥
Kat :)
ole two wheels
  • ole two wheels
« Reply #9 on: September 14, 2017, 04:00:14 PM »
Now you can do a Utube thingie on how to cancel the oil light. I can't wait
Mac
2012 Kymco DT300
1996 Honda Shadow Spirit 1100
Nireen
« Reply #10 on: September 14, 2017, 09:21:24 PM »
sh** i didn't pay attention to well! LOL
Kat :)
bluesin
  • 2012 DT 300i
« Reply #11 on: September 14, 2017, 09:25:15 PM »
Well then... You're fired .  ;)
Nireen
« Reply #12 on: September 15, 2017, 07:59:49 AM »
LOL  OK if someone tells me how to put the light back on I will figure it out and do a video :D
Kat :)
gwdoiron
« Reply #13 on: October 24, 2017, 03:31:04 AM »
The ECU knows how many miles have elapsed since the last time the service light was reset.
It lights up once the recommended service interval mileage has passed (on the Xciting 250, for example, it is 1200 miles).
Once the warning has been reset, it starts over at 0.
If the light is on, you should change the oil.  It doesn't have to be a drop-everything-now-and-do-it type of thing, it can wait a week or two.
Once the oil is changed, reset the lamp.  You should also check your user manual to see when the transmission oil needs to be changed; they typically are changed at the same time, but there is no light for this.
This way you never destroy your drive train because you forgot to change the oil.
« Last Edit: October 24, 2017, 03:33:01 AM by gwdoiron »
