Author Topic: Variator tool  (Read 1836 times)
Mr. Paul
Variator tool
« on: September 12, 2017, 11:43:59 PM »
Can anyone tell me where I can get a tool to hold my variator in place? I have a tool to hold my clutch, but I have not come up with a satisfactory tool to hold my variator securely while I torque it with my wrench.
2009 Kymco People 150
1993 Honda Helix
big blue
Mr. Paul
1993 Honda Helix
hypophthalmus
Re: Variator tool
« Reply #3 on: September 13, 2017, 02:05:59 AM »
I seem to recall reading that strap wrenches work.
big blue
Re: Variator tool
« Reply #4 on: September 13, 2017, 02:14:42 AM »
Sorry about that.
Mr. Paul
Re: Variator tool
« Reply #5 on: September 13, 2017, 09:38:15 AM »
I bought one with a heavily reinforced rubber strap (2000 lbs of torque) Not enough surface area on the edge of the variator for the strap to grab. It works great on the clutch though.
1993 Honda Helix
Re: Variator tool
« Reply #6 on: September 13, 2017, 11:28:55 AM »
Impact, air or electric.
boo
since you have no holes in the variator face
« Reply #7 on: September 13, 2017, 12:31:22 PM »
I second what CROSSBOLT suggested. An impact wrench.
Personally, I have not had much luck with strap wrenches. They tend to slip.
300GTI black
Pro 2A - member GOA & NRA
Re: Variator tool
« Reply #8 on: September 13, 2017, 01:59:28 PM »
  and you can get the torque limiting extentions down to 70 foot Lb.s  for putting nuts back on,.
wentwest
Re: Variator tool
« Reply #9 on: September 13, 2017, 04:08:19 PM »
I made a holder out of a rectangle scrap of 3/4 inch plywood (you can use whatever you've got and if it's thin use two layers).  Toward one end, about 4 inches from the end, you cut a hole big enough to allow a socket through to get to the big nut holding the variator.  Then you drill 4 holes through in a square pattern about 3 or 4 inches on each side, centered on the big hole you drilled for the socket, and put through large bolts with a washer under the head and a large washer and nut on the other side (facing the variator) with enough bolt sticking out so that they reach between the vanes on the variator.   The plywood should be shaped so it covers the variator and reaches far enough in one direction to jam against the frame of the scooter or the floor when you rotate the variator with the hole over the variator nut and the 4 bolts stuck between the vanes of the variator.   Then put your socket through the plywood onto the nut and unscrew it.
If the scooter wants to rise up off the floor while you are unscrewing the nut, either sit on it yourself or get your overweight brother-in-law to sit there while you push on the breaker bar.
If this isn't clear, reply and I'll take a photo of the one I made.
Mr. Paul
Re: Variator tool
« Reply #10 on: September 13, 2017, 10:29:03 PM »
De dee, do the torque limiting extensions work with an impact wrench without having to hold the variator? I am unfamiliar with the extensions. Sure sounds like a good solution to me.
1993 Honda Helix
MJR
Re: Variator tool
« Reply #11 on: September 14, 2017, 05:57:00 AM »
Not sure how accurate they would be not holding it. A lot of stuff I can hold by hand, yes it may slip a little but that's ok.
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
Mr. Paul
Re: Variator tool
« Reply #12 on: September 14, 2017, 09:54:24 AM »
Thx MJR. I could hold it one-handed.
1993 Honda Helix
Re: Variator tool
« Reply #13 on: September 15, 2017, 06:38:25 PM »
Mr Paul..do you have a picture of your variator?
LidoCA
  • I LIKE chinese plastic.
Re: Variator tool
« Reply #14 on: September 16, 2017, 02:25:08 AM »
Amazon has many different types. Check for the type that you need.
Steve
2013 LIKE 200i LX.
2016 Yamaha SMax
2014 Yamaha Majesty
La Mirada, Ca.
