Author Topic: Agility 50 start problem  (Read 1091 times)
Pinchy1111
« on: September 14, 2017, 01:04:04 AM »
Hi everyone this is my first post here.
Ive had my kymco about 3 months and it was going great but one the electric start stopped working.
I bought a new solenoid still nothing. I took the starter motor off and tested it with a battery and that worked. So wjat other possibilities are there? Ive put a multimeter on my battery terminals and it seems to shows its charged and putting out enough. Anyone recommend anything would be great. Thanks!!
eamartin
Re: Agility 50 start problem
« Reply #1 on: September 14, 2017, 10:35:13 AM »
What year?  How many miles?
Pinchy1111
« Reply #2 on: September 16, 2017, 07:29:08 AM »
Its a 2013 with 12000 kms
eamartin
« Reply #3 on: September 16, 2017, 11:48:42 AM »
How old is the battery?  Have it load tested.  Is there a relay between the starter switch and the solenoid?  Can you do a test by-passing the starter switch and going directly from the battery to the solenoid?
Jp6940
« Reply #4 on: September 25, 2017, 10:02:30 PM »
 Will  it kickstart ?
 If so I would check your  grounds
Pinchy1111
« Reply #5 on: September 27, 2017, 09:24:31 AM »
Will  it kickstart ?
Yep still kick starts every single time no problems
JJJoseph
  • Kymco Sento
« Reply #6 on: October 13, 2017, 08:51:28 AM »
eamartin & Jp6940 have the right approach.  The culprit is likely in the wiring, maybe so obvious as the positive wire to the starter.
