Did you miss your
activation email
Scooters - 125 to 300
People GT 300i
Gt300i TPS adjustment
Topic: Gt300i TPS adjustment (Read 3265 times)
jefd
Newbie
September 25, 2017, 11:00:54 PM »
Hi, anyone know how to properly adjust tps ? The bike ran good except for the slight flat spot I complained about, I loosened the tps set screw, moved it ,flat spot is gone ,but light is on now, I did the reset, but still on!
yao
Jr. Member
Re: Gt300i TPS adjustment
September 26, 2017, 12:44:59 AM »
I believe mine was .6v. Take a volt meter and test it with the tps connected, there are 3 wires, one power, ground and signal. You are looking for signal wire, the voltage will change as you rotate tps. You can not clear error codes without kymco computer, I have tried.
Last Edit: September 26, 2017, 12:46:38 AM by yao
West Tennessee, USA
September 26, 2017, 10:46:32 AM »
You got it out of the voltage range and the ECU caught you! Sneak it back until the light goes out. Turns out the bike will run darn near where ever it is put BUT the ECU gets really cranky with that warning! The set point in the service manual is incorrect so you need the service tool to really set it right so it shows 0% when trottle is closed and 100% when opened to the stop. However, you CAN set it like I said above and be pretty darn close. This still under warranty?
jefd
Newbie
Reply #3 on:
September 27, 2017, 12:21:53 AM »
Thanks for the replys, No its a 2012 only 2500 mi, it was good till I messed with it, but my bog or flat spot is gone! the Kymco manual says 5 volts and you can reset the light? funny the Clymer manual was a little more clear ! thanks
West Tennessee, USA
Reply #4 on:
September 27, 2017, 11:43:39 AM »
Mine was set at about .4 volts from the factory. That equates to 0% throttle closed and 100% throttle WFO (Wide Open) on the Kymco Analyzer Tool. So the tech manual is wrong. We can work around that. Diddle around until the light stays off and the flat spot is gone and you should be good.
jefd
Newbie
Reply #5 on:
September 28, 2017, 12:06:32 AM »
where can I get a Kymco Analyzer Tool
West Tennessee, USA
Reply #6 on:
September 28, 2017, 12:43:37 AM »
Dealer or parts house. 'Bout $200.00 in 2013. I'll getcha the part number tomorrow. Do you have a service manual? That gives pretty good instruction on how to use the tool.
jefd
Newbie
Reply #7 on:
September 28, 2017, 01:35:08 AM »
Got the manual thanks
West Tennessee, USA
Reply #8 on:
September 28, 2017, 03:48:23 PM »
Kymco analyzer #3620A-LEB2-E00.
jefd
Newbie
Reply #9 on:
October 02, 2017, 12:19:54 AM »
Cleared Celp light today! no problem, Now !Thanks J
West Tennessee, USA
Reply #10 on:
October 02, 2017, 10:17:02 AM »
Nah, nah, nah, Jef! Gotta tell whatcha did!
jefd
Newbie
Reply #11 on:
October 08, 2017, 02:01:34 AM »
Just what I said, I cleared light, but flat spot at WOT is back ! Got to play with the TPS and see where the sweet spot is, If there is one! Also what kind of # should I be seeing per tank full of fuel ?
Last Edit: October 08, 2017, 02:06:20 AM by jefd
West Tennessee, USA
Reply #12 on:
October 08, 2017, 07:09:51 PM »
Your bike is less than 2000 miles since new, right? Milage will continue to improve as it mates in. Should stabilize after 6 to 7000 miles. Expect 65 -68 mpg on 10% ethanol, 68-70 non-ethanol 87 octane (R+M/2) at first. Should improve to 68-70 ethanol, 72-75 non-ethanol after mating in when ridden conservatively on acceleration and around 60 mph cruising. That means riding like an old guy with nothing to prove!
jefd
Newbie
Reply #13 on:
October 23, 2017, 11:43:28 PM »
Would it make sense I am seeing 65 miles per tank? 2.1gallons fills me up till all the bars are gone!
West Tennessee, USA
Reply #14 on:
October 24, 2017, 12:57:05 PM »
65 miles perTANK is way, WAY off! Even 2.1 gallons for 65 miles is only a little over 30 mpg. Half of what is capable. Big problem!
Been thinking on this all day. Please check your oxygen sensor and make sure it is plugged in. Then do a resistance check.
Last Edit: October 24, 2017, 10:04:54 PM by CROSSBOLT
Back
