Author Topic: Help please please 3 random wires  (Read 2011 times)
118118
Re: Help please please 3 random wires
« Reply #15 on: September 27, 2017, 10:28:10 AM »
HI,
Forget changing the CDI. Forget the TPS sensor and just leave the wires hanging free. Fit the old or new carb. Set the idle screw 2 turns out from fully screwed in. Make sure you have good clean fuel in the tank. Make sure you have a vacuum line to the fuel tap to open it when cranking the engine. fit a vacuum line to the carb fuel pump (on the side of the carb). Connect the auto choke connector and give it a go. Use the electric starter rather than the kick start.
Good luck.   ;)
« Last Edit: September 27, 2017, 10:32:02 AM by 118118 »
msecanmo
« Reply #16 on: September 27, 2017, 02:13:00 PM »
HI,
Good luck.   ;)
Here's an electric scheme
Poslano sa mog Redmi 3S koristeći Tapatalk
