Author Topic: slow acceleration  (Read 7626 times)
magordon7
Re: slow acceleration
« Reply #15 on: July 17, 2010, 09:37:34 PM »
ok art.. check this. http://www.pjmotorsports.com/keihin-jets.html#main jets i may have found some jets for stock carbs, although im not sure of the size that i need. # 95 to 105 i get that but 5mm wide or 6mm? how long and such.
sidthesloth
  • Kymco ZX50
« Reply #16 on: July 17, 2010, 10:57:53 PM »
Nice find Magordon, there has been discussion on here before about the stock Keihin jets, it seems that there are so many no one knows which one to order and the dealers seemed to be unsure as well. For the record, I reckon the 1001-806 is the correct one for the stock ZX50. Once again, nice find, and welcome to the forum.
magordon7
« Reply #17 on: July 17, 2010, 11:11:33 PM »
thanks bro! hey the find came fairly easy thanks be to google... still researching see what else i can find
art
« Reply #18 on: July 17, 2010, 11:15:43 PM »
Very nice find I've been all over the place havn't found these guys .If you have the dreaded pb its the 7mm x 5mm x 3mm or 99101-116,thats the one for the stock people 50 not sure about the s9 someone here should know,could not find anywhere,and pilot jets too!!!  :-* x  :-* x   :-*   ;D
magordon7
« Reply #19 on: July 17, 2010, 11:22:02 PM »
also i checked my spark plug agaist that website that art posted for reading plugs. and mine turns out perfect chocolate brown described as "the best" on that page. so tuning does not seem to be an issue. my guess is there isnt a good balance between intake and exhaust that henders my acceleration. so my next step should be k&n style filter and up on jet size. the 48mm filter will fit on the stock carb i believe. sound right guys? here is the filter i am looking at http://www.scooterpartsplace.com/High-Performance-K-N-Style-Scooter-Air-Filter.aspx
art
« Reply #20 on: July 17, 2010, 11:42:24 PM »
I needed the 38 on the people 50 Think i got a 43mm k/n to work different style.Thats the one i wanted though.Once you put the k/n in you will be running way lean don't go far but check your plug for reference
magordon7
« Reply #21 on: July 17, 2010, 11:48:37 PM »
is it possible just to open up the stock jet in order to get the correct tunning once i add the filter? also after i read the plug can i clean it off and use the same one to read again
art
« Reply #22 on: July 18, 2010, 12:26:53 AM »
You can open it up,but i think the jump in size may be a bit too much for the stocker you start to take the cone out of the jet,may still work fine,It's good to have a hand full of plugs when doing this,once they get toasty it's hard to tell some times whats going on,plus these t2's eat plugs from time to time so its good to have a few spares at least three.If you plan to open your jets get the torch tip cleaner set at a welding supply house.something like this is your best bet if you go this rout.It is cheaper in the long run if planning more mods. Those jets are a little pricey at the site( but nice to have when no one else caries them)Around $4.00 most places.
sidthesloth
  • Kymco ZX50
« Reply #23 on: July 18, 2010, 12:55:15 AM »
G'day Magordon, I have 3 of those type filters, from 3 different suppliers, they seem to work ok but one thing I found with all of them is that the chrome end cap is not sealed properly, like they were stingy with the glue. If you buy one, check it and if you see light through the join make sure you seal it before you use it. With mine I paid $10 for one from hong kong, $20 for one from my local bike shop, (yep, we have one of those) and the other one came with the carb and inlet kit I bought from an ebay seller. As far s I can see, they are all made from the same factory, different seller, different price. If you want to pay a bit more you could buy the genuine K&N filter, will be top quality, but I don't know how much more.
magordon7
« Reply #24 on: July 18, 2010, 05:16:19 AM »
thanks guys again... i found a k&n site that has a size that will fit...they dont give them away tho at about 65$ but they do come as a pair so not too bad i guess. i got a complement today from a guy on a ninja... he was amazed that i had an exhaust on my scooter.. haha if he only knew
sidthesloth
  • Kymco ZX50
« Reply #25 on: July 18, 2010, 05:40:26 AM »
I believe the K&N filters are reusable, as in clean and reuse. They do cost, more but I have never heard anything negative about them.
Except the price. :)
art
« Reply #26 on: July 18, 2010, 06:11:42 AM »
I agree They are more pricy but a good prodect,somone's a little bit HIGH!Could be  ME! nothing wrong with having 2 they do breath better than any other I have tried and haveing a backup is good or was that a hickup,seen them up to $85 a pop! I'll take the  other if you don't need it! Ha!
« Last Edit: July 18, 2010, 06:20:34 AM by art »
magordon7
« Reply #27 on: July 18, 2010, 07:16:30 AM »
lol well i start my new job monday so maybe ill be able to afford nice stuff like that :)
sidthesloth
  • Kymco ZX50
« Reply #28 on: July 18, 2010, 07:26:29 AM »
Those cheaper filters I got have a removable mount rubber. Tha one I bought locally was for a 54mm carb, I just put on my 48mm mount rubber and is all good.
« Reply #29 on: July 18, 2010, 03:16:59 PM »
..the filter fell off the mount of the one i had on my A50...
..somewhere, it's out there...all alone....
