Author Topic: Upgear kit for 2013 super8-2t  (Read 1755 times)
Ricky t.
« on: October 17, 2017, 11:36:17 PM »
2013 Super8-2T. 72cc polini bbk, mallosi 19mm carb, uni filter, 115 main jet, Technigas Q-tre exhaust, stock variator with dr.pulley slider 6.5, stock clutch...I way 250lbs. Running 42mph on flat land. Premix 32:1. I am looking for informationon upgearing this bike. Help me.
Ricky t.
Re: Upgear kit for 2013 super8-2t
« Reply #1 on: October 18, 2017, 11:45:22 PM »
Racing planet offers Jasil Transmission gear up kit for super8 -2t. Gives18% gain.
agoncalvesjr89
« Reply #2 on: October 24, 2017, 06:12:01 PM »
my friend, if your only getting 42 mph you have a problem.. Might be your running way to Rich with that 115 main jet,, or something... i have a Super 8 2t with only a 88 main jet, racing exhaust , and variator/Sliders, modded air box.. and i get 47MPH gps verified. 45-46 all day .  My close friend (also member here) has a super 8 2t with the sh**tiest naraku 70cc kit on it, with just a 92 main jet and STOCK EXHAUST modded and welded and get 49mph . he weighs about 230. On mine when i drop down from 88 to 86 it leans it out to where its alittle faster, but to lean. BUT i also tried a 90 in their and it dropped down to 43-44 mph. To big of main jet means sloppy wet combustion , to much gas,,, not enough clean burn.
2013 SUPER8 2T 50
70cc MALOSSI KIT
STOCK CARB MAIN JET AT 98 , STOCK AIR BOX SNORKEL REMOVED.
NARAKU VARIATOR 6 GRAMS SLIDER / ROLLER COMB.
TECNIGAS NEXT R EXHAUST
SLIGHTLY LONGER THAN STOCK GATES DRIVE BELT.
TOP SPEED 50ISH , TONS OF POWER. 45MPH CRUISING
agoncalvesjr89
« Reply #3 on: October 24, 2017, 06:13:49 PM »
I also am friends with a Mechanic / salesman at Scootertuning.ca and am aware that their are no gear up kits for the SUper 8 2t. It has a unique final drive where the Super 9 and other "kymco" branded Air Cooled gear up kits WILL NOT FIT> ive spoken to stage 6 directly as well about this, inquiring about a discontinued kymco gear up kit for super 9, people, and some others. BUT wont fit a super 8 2t. sh** is lame
2013 SUPER8 2T 50
70cc MALOSSI KIT
Ricky t.
« Reply #4 on: November 30, 2017, 09:31:50 PM »
I jet according to my plug see. The way you suppose to. Changed pilot jet from 55 to 60. Main jet to an even larger #118. Never seen a happier plug reading. Now runs 47mph. Big bore kits and carbs are not much faster overall.. Just know they do get there quicker. I leave guys at the light everyday. Some on big bikes.
Rocket Salad
« Reply #5 on: December 04, 2017, 05:14:07 AM »
Hi all from Queensland Australia. First post after lurking for a while. I'm about to purchase a new super8.
What's an up gear?
My old SYM Jolie hit almost 60mph with the 70cc kit and many other upgrades. Why can't the super 8  reach this speed?
Regards
Rocket Salad
