Author Topic: Bench test your carburetors  (Read 1006 times)
eamartin
« on: October 27, 2017, 04:06:37 PM »
Have you ever re-assembled and installed your carb only to find out that it leaks?  Could be it's assembled incorrectly, the float won't float or is out of adjustment or the needle is damaged or....  Sometimes the carb is easy to access.  And sometimes it's not.  I found it a lot easier to just bench test my carbs before installing them and I built a small stand out of plywood scraps. adding a fuel container on top to deliver gas through a fuel line to the carb.  If you do a lot of carburetor work, this could be a useful device for you.  Of course, if you only do 1 carb in a blue moon, it's probably more trouble than it's worth.
« Last Edit: October 27, 2017, 04:08:18 PM by eamartin »
Re: Bench test your carburetors
« Reply #1 on: October 27, 2017, 04:11:38 PM »
Nice job, Martin! Man after my own heart! You even painted it. Mark of a pro. Also great idea. Nothing more discouraging than having to put something together only to have to tear it down because of some little thing.
stuo
« Reply #2 on: October 27, 2017, 05:59:55 PM »
I love it! Beautiful carpentry work, especially those gussets. Thanks for sharing.
Stu
2009 GV 250
schmittck
« Reply #3 on: December 03, 2017, 03:37:36 AM »
YES! been there. After a painful reassembly, leaks... the worst. Great idea and thanks for sharing.
eamartin
« Reply #4 on: December 03, 2017, 07:29:29 PM »
Thanks for the comments.  This stand ain't rocket surgery......and it's cheap.
Ernestt
« Reply #5 on: December 06, 2017, 07:28:17 PM »
love it
2009 kymco people 250s
ole two wheels
  • ole two wheels
« Reply #6 on: December 06, 2017, 11:40:58 PM »
Nice set up Ernestt. Just what does it test for. Leaks, I'm sure but anything else? Thanks, Mac
Mac
2012 Kymco DT300
1996 Honda Shadow Spirit 1100
eamartin
« Reply #7 on: December 07, 2017, 03:08:06 AM »
Primarily it tells you if your float valve is closing properly.
