Author Topic: Am I being ripped off?  (Read 3431 times)
ss10gotanks
« on: October 28, 2017, 07:02:06 AM »
Hello everyone! I have a Kymco Xciting 500RI ABS that I bought a couple of months ago. I was having some problems with it shutting off so I took it to be fixed at the only scooter repair place in town. I was quoted 220 to fix it. I was told that it needed its Stator replaced.
So what I would like to know is how long should it take to replace this? Is it a hard repair? My bike has been in this shop for two months and they finally called me today and was like BTW the total is 440. When I complained, I was told that it took several guys over 6 hours to replace this part and that they where under charging me for the hours it took to repair it and that they even had to add more oil cause they needed to drain it to get to it.
I haven't been able to find much on how difficult this is to replace or how long it typically takes to replace. Is it normal for the quoted price to change so drastically without calling to see if i'm okay with the price doubling?
Any thoughts on this would be super helpful. I have a feeling that i'm being taken advantage of and would like to go into the store with some ammo tomorrow or monday. If you've changed this part- how long did it take you? The part they told me was like a 90 or something.
« Last Edit: December 16, 2017, 05:41:07 AM by ss10gotanks »
jeeves
  • Dubrovnik, Croatia
Re: Am I being ripped off? *Please answer quickly*
« Reply #1 on: October 28, 2017, 10:55:52 AM »
If it takes 4 "mechanics" 6 hours to replace a stator then you definitely need to find another shop.
Can't comment on the total price, I don't live in the US, but giving you a total that is 100% more than what was given at the begining is not something that I would just say ok and pay.
« Last Edit: October 28, 2017, 01:06:42 PM by jeeves »
Agility City 125
« Reply #2 on: October 28, 2017, 12:13:42 PM »
They should have consulted you BEFORE they ran up the clock. What made the stator fail? Where was this shop?
willembop
« Reply #3 on: October 28, 2017, 03:05:38 PM »
I think six hours of work sounds about right. I just did this job on my Xciting 500 a couple of months ago. First removing a bunch of body panels (about 20 minutes work). Then drain coolant and remove water pump (15 minutes). The remove about 20 bolts that hold the engine right side cover on (20 minutes). Then I had to remove something on the rear suspension (I don't remember what) that prevented removal of the side cover (
willembop
« Reply #4 on: October 28, 2017, 03:27:25 PM »
Whoops, wasn't finished and somehow hit the POST button. Here's the rest of my message:
I think six hours of work sounds about right. I just did this job on my Xciting 500 a couple of months ago, and I was surprised at how difficult the job was, having done numerous motorcycle stator replacements in the past (which I remember being much easier). I'll describe the procedure and estimate the time it took for each process (not counting head scratching and confusion). First removing a bunch of body panels (about 20 minutes work). Then drain coolant and remove water pump (15 minutes). Drain engine oil and remove oil filter (10 minutes). Remove about 20 bolts that hold the engine right side cover on (20 minutes). Then I had to remove something on the rear suspension (I don't remember what) that prevented removal of the side cover (15 minutes). Disconnect electrical plugs (5 minutes). Finally removed side cover. The side cover gasket was torn upon removal, and it took another 10 minutes to scrape the sealing surfaces clean. Then I had to order a new gasket (it cost about $25 and took 2 weeks to arrive). It took about 10 minutes to install the new stator onto the engine side cover and torque it in place. When the gasket finally arrived, reinstalled engine side cover and tighten the 20 or so bolts (30 minutes). Reattached suspension piece (5 minutes). Install water pump (5 minutes). Install new oil filter, add oil and coolant (20 minutes). Start up and check for proper operation, leaks, etc. (30 minutes). Reinstall body panels (30 minutes). Road test (30 minutes). So I think the times I've estimated add up to almost 4 hours, and I'm probably forgetting some important step. I think it actually took me about six hours of work. I think the dealer shops around Virginia are charging in the neighborhood of $100 an hour. So $440 seems to be a fair charge.
Mr. Paul
« Reply #5 on: October 28, 2017, 03:52:46 PM »
The part is around 70 bucks plus shipping, so 90 dollars sounds about right. The issue is; was it a quote  or an estimate? If you have documentation, a quote is a binding document. An estimate is not. It is never, ever OK for a shop to increase a charge 100% without a courtesy call to the customer. If it were me I would offer them $330.00 dollars for the labor. Thats halfway between what you were told and what you were charged. And then I would never use them again.
2009 Kymco People 150
1993 Honda Helix
« Reply #6 on: October 28, 2017, 08:46:57 PM »
Correct me if wrong but seems that stator failure is related to rectifier-regulator failures for the 300 to 700 series Kymcos. The substitute is a Honda reg-rect by Shendengen. Same connectors, same number and color of wires, bigger heat sink. Should fit most scoots. I have not had to try one but Peter Kapitar (arrow76) in Hungary has had this fix since early this year and it works great. Not much can go wrong with a stator but it can be destroyed quickly when the rect-reg take a puke. This is someting I suspect the dealer techs are totally unaware.
stuo
« Reply #7 on: October 28, 2017, 08:54:57 PM »
I second Mr. Paul's motion: At the least, you should have gotten a call beforehand, but I suspect the mechanic(s) didn't know the extent of the labor involved until they were knuckle deep and hours into repairing your bike. That's your cost for the shop hiring ignorant mechanics: the customer pays for their education.
If you have a written estimate you have some moral/negotiating leverage but they have possession of the bike, so consider it a ransom negotiation. Here in California a shop can hold your bike and lien sale it for failure to pay the bill, but I'm pretty sure they will settle for something less then the full pop if you are friendly but firm in your negotiating, and not too righteous. Or you can break into the shop at night and steal your bike....
2009 GV 250
stuo
« Reply #8 on: October 28, 2017, 09:40:13 PM »
P.S. Sorry for the glib comment about stealing your bike. Some tips: Assume the shop is honest and not trying to rob you; convey the attitude that you want to continue to do business with them (even if you don't) and you would be a very happy/satisfied customer if you got some relief (discount) on the bill due to the enormous difference between the estimate and the final cost and...the lack of a courtesy call before the job was done. Unless the owner is a fool, he wants your repeat business so your main strategy is to convince him to make you a happy/repeat customer by adjusting the bill. Arguing that his mechanics spent way too much time on the job wouldn't work with me when I had a shop so I don't think that will work, even though you are right.
When he does hit that magic number that you can live with smile, thank him, then firebomb his shop that night. (Oops, there I go again, sorry)
2009 GV 250
Forbes1964
« Reply #9 on: October 29, 2017, 07:39:41 AM »
I don’t know the laws concerning estimates on cycles. But in Florida an auto repair facility can NOT exceed a written estimate by more than 10%  up to 100.00 without permission from the customer by a phone call or in writing. A phone call must be documented. If there is no written estimate or signature saying that an estimate is not requested then the max they can make a customer pay is 150 or so.
2009 Xciting 250
stuo
« Reply #10 on: October 29, 2017, 08:08:43 PM »
Damn good law, Forbes1964. Almost a good reason to move to FL. But:
Suppose the shop owner says: "F--- the law, I'm not releasing your bike until you pay the bill." What recourse does the owner have? Small Claims Court?  Hire-a-thug? What I'm getting at is that it is smarter to negotiate a ransom then it is to fight it out legally, even if you know you will prevail...eventually. We are talking a couple hundred bucks here, fer crissake.
2009 GV 250
ss10gotanks
« Reply #11 on: October 30, 2017, 04:48:04 AM »
Thank you for all the incite, I really appreciate. I believe what I've gotten out of this is 6 hours sounds about right. Although if ya'll happen to not be mechanics I'd imagine a shop should have it done sooner. But I won't harp on that. I'm glad ya'll agree that they should have contacted me. I believe it was a estimate and not a quote I guess. Cause I never signed anything. I'm just boggled that they thought it'd be totally fine to just double it without saying.
I know its just a couple hundred bucks. I was desperate to get answers before I go up there b/c to me right now 200 dollars might as well be 2 grand. I'm worrying about keeping the lights on and stuff let alone paying 200 more dollars for a repair. but i'm in a position where its my only transportation so i'm literally at these peoples mercy. If they had told me 300 or more originally I would have turned it down and either attempted to do it myself with a car-smarter friend. Or keep my battery charged. So if they won't come down on the price or do a payment plan, then i'm not sure what to do other then right a horrible review so that the next person won't use them.
pipster326
« Reply #12 on: October 30, 2017, 08:54:07 AM »
Obviously they didn’t know what they were doing or talking about. You don’t double the price, without getting approval first. They should honor the original price and eat the extra expense
« Reply #13 on: October 30, 2017, 12:20:13 PM »
This sounds like your only transport. Negotiate either lower price or payment plan. The fact is (kept to yourself during negotiations) dealer techs have, generally, little or no experience on these bikes. The techs generally are under pressure to fix quickly to get their commission so they just throw parts at a problem until it goes away. Very few and we could name two are on this forum or even read it. Please keep us posted on what transpires.
stuo
« Reply #14 on: October 30, 2017, 06:59:04 PM »
Everyone gave good advice and you should be able to get some relief in your negotiation. Motorcycle shops serve a very small market and they cannot abuse customers and stay in business long. If appealing to reasonableness doesn't work how about threatening to picket the shop with a sign saying "Beware this shop. Let me tell you my experience with them." I always wanted to try this last ditch strategy. In the USA it's legal to protest and picket, as long as you don't block traffic. How long do you think they could put up with someone picketing their shop?
Let us know how it went. You might also mention you have a lot of fellow scooterists watching them and how they treat you.
2009 GV 250
