Author Topic: Scoot STILL refuses to go past 70km/h??  (Read 16964 times)
jbcinzio
  • I was the second gunman on the grassy knoll....
Re: Scoot STILL refuses to go past 70km/h??
« Reply #60 on: July 25, 2010, 11:11:51 AM »
Soumds to me like the 50 4T engines are a real pain in the ass to mod.......  >:(
I only want 85km/hr dammit!!!!
Josh.
This message was posted using 100% recycled electrons.
art
« Reply #61 on: July 25, 2010, 05:48:47 PM »
Don't know if it's safe or not super,but since nothing else has worked I suspect you have this in your scoot,look at the pic and see if it matches yours... Pink wire to the ext?   I just went throught a s200 and pulled one wire at a time till I found the right one,because no one has the info out yet. You can remove these wires from the houseing with a small screwdriver incerted in the bottem between the plug and terminal  and a little twisting and pulling
Super8504T
« Reply #62 on: July 25, 2010, 06:08:03 PM »
My CDI is like this with the eight pin connector and the two pink wires (which I have removed from my connector now so it only has 6 wires.
Im just a bit aprehensive because I know that once CDI's have been modded they have a tendency to either fry.. mysteriously get water in them or just be in the mood to not work  ::) :P
I might try it.. but with what??
art
« Reply #63 on: July 25, 2010, 06:17:24 PM »
Yours does look different I dont know  ???  some of them you just have to replace. What is this pink ext wire you mentioned,mayby try that one first.
jbcinzio
« Reply #64 on: July 25, 2010, 06:38:46 PM »
Hey bud, here's a pic of my CDI & Connector.
My CDI looks the same, however my Connector is different....
I went for a really good ride tonight (around 1:00am actually) and this is what i figured out...
On the flat, my stock (variator bush replaced/unrestricted) Like 50 4T was doing 75km/r.
On a slight downhill slope, however, I managed to get the scoot up to 87km/hr.
Now here's my thought..... If mine was restricted, wouldn't I feel the rev-limiter cut in and spoil the fun?
Or at least, stop the acceleration.... In my car, when the rev limiter cuts in it goes "bap bap bap bap" really fast (like 10 times a second) as it kills the spark intermittently and will not go any faster unless you change gear or back off the loud pedal. It doesn't slow down.... It just hits a "wall" and won't budge an inch.
My scoot does none of that. I think the only thing holding mine back on the flats is breathing (inlet & exhaust), and fuel supply (bigger carb is on its way)  ;D
I'm starting to think mine doesn't have a limiter.
Josh.
art
« Reply #65 on: July 25, 2010, 06:45:09 PM »
Id say your not restricted usually kicks in around 40 mph here in the states,you would notice it, there are no restrictor wires in your pack at all. Cool!
jbcinzio
« Reply #66 on: July 25, 2010, 07:00:51 PM »
So is there any point in trying to track down a "Race CDI"?..... More Power? Advanced Ignition Timing? ... any of these so called benefits true, or is it just a "Sales Pitch" from guys trying to flog their wares?  ???
Thanks for the help btw,
Josh.
Super8504T
« Reply #67 on: July 25, 2010, 08:22:12 PM »
The pink wire is the two in the picture.. the
 violet wire on the plug connector  Ive taken them
our completely.. so no pink wires are on the CDI plug conbector
so theres really nothing else I can do to derestrict it apart from
cutting into it or buy another race CDI.. race CDI did provide me m
provide me more horsepower and no limit speed. With the current standard one sxo
scoot is more sluggish :/
art
« Reply #68 on: July 25, 2010, 11:29:59 PM »
Hey jbc once derestricted the stock seems to be fine,unless going for race mod you should be fine.
Super I don't know what to tell ya,the violet on some is the one. You are the only one I've heard  of with this problem  ???  Then some guys like jbcinzio just luck out got a model probably for another market (Score!)
« Reply #69 on: July 26, 2010, 11:28:46 AM »
..if you can get that much, then it's not restricted.....
Super8504T
« Reply #70 on: July 26, 2010, 05:19:32 PM »
I experimented a bit before and decided to re-connect the pink wire loop to see what it would do.. it restricted the bike to 31mph.. I then took it back out and it allowed 43 mph.. I think it is the standard CDI that is programmed to allow no more than say 7000rpm or something.. buying a race CDI allows higher rpms and so more speed. I think that is the case now.. to just get a new race CDI when I can.. my current race CDI is buggared. Still wont start the bike.. its had it I think.. short circuited  :-\
Do any of you know of any "cheap" race CDI's for the Super 8? Dont fancy paying in the £115 region again  :P
art
« Reply #71 on: July 26, 2010, 07:23:49 PM »
Damn! did ya try any other wires. mayby order another reseal and send back  ???
« Reply #72 on: July 26, 2010, 09:00:42 PM »
...maannn, don't buy "cheap" if you can stand it..save your pesos and buy a good one....
..there are "gy6 50" parts and there are "performance" parts...
..your kymco will love you for shelling out a few extra skins for the better parts...
peace
