Author Topic: Valve tool  (Read 1774 times)
Ernst
Valve tool
« on: October 30, 2017, 09:38:55 PM »
 Every time I adjust the valves on my P250S I wish I had the proper tool to hold the adjuster in place instead of needle nose pliers.
 I have not sourced the proper valve tool and service manual doesn't give a part number for it.  Has anyone found or know where I can get one?
Doh! Ebay!
Okay I ordered a set for $15 8mm,9mm and 10mm
Thanks anyway.. Got post happy.
« Last Edit: October 30, 2017, 09:54:23 PM by Ernst »
Re: Valve tool
« Reply #1 on: October 31, 2017, 01:49:07 AM »
Doh! Ebay!
  THE ADJUSTER IS A sqare bolt head  just the right size as a # 2 robertson screw driver with the tip removed,
Ernestt
Re: Valve tool
« Reply #2 on: November 02, 2017, 02:17:01 AM »
i used a square headed screw and bent it to a 90 degree angle i didn't pay anything for it i have a coffee can full of them
2009 kymco people 250s
Ernst
Re: Valve tool
« Reply #3 on: November 12, 2017, 01:33:42 AM »
I got my  set and plan to adjust valves tomorrow.  I will see if I have the right one.
RatBob
Re: Valve tool
« Reply #4 on: November 27, 2017, 08:11:20 PM »
I use the pliers end of my stripper/crimper, never had a problem that I saw the need for a special tool, but I might try the screw idea since it's free.
