Author Topic: can't get to spark plug  (Read 2668 times)
MD
« on: November 01, 2017, 10:29:41 PM »
have a 2012 Kymco MXU 500i and would like to check the spark plug.  i can see it under the left fender, but how do you remove it? does not seem to be any clearance...do i have to remove something first? owners manual is NO help.
« Last Edit: November 22, 2017, 08:52:23 PM by MD »
aaron8
Re: can't get to spark plug
« Reply #1 on: November 16, 2017, 04:29:05 PM »
you have to undo the plastic surrounding the fuel tank and then remove the tank. unless it is fouled I would leave it alone
beermak
« Reply #2 on: November 18, 2017, 12:52:55 PM »
Put an iridium plug if aint easy access and never worry again!!
Enviado desde mi iPhone utilizando Tapatalk
Somnium
« Reply #3 on: November 18, 2017, 09:56:54 PM »
I just tried to check spark plug in MXU 400 and realised that I will need jointed sparkplug tool to remove it. There is no room for "normal" sparkplug tools. Another option is to remove the fuel tank.
Bratman2
« Reply #4 on: November 19, 2017, 01:04:56 PM »
Guys, unless your 500 and 400 are way different than the 450 it is fairly easy to remove the tank plastic and fuel tank. You may very well need to check valve clearance anyways.
http://www.kymcoforum.com/index.php?topic=23798.0
« Last Edit: November 19, 2017, 01:06:47 PM by Bratman2 »
2019 UXV 700i LE Hunter
2014 MXU 450i
2004 Mongoose 90 (grandson's)
2010 Grizzly 450
