Author Topic: Stripped the head off my drain bolt  (Read 1137 times)
revsin
« on: November 18, 2017, 05:27:41 AM »
Well that was annoying, went to change the oil. Got er up, put on the appropriate socket and..... stripped the bolt head into a nice useless chunk of Chinesium.
Pretty sh**e quality metal me thinks, but I mostly gotta blame the dude before me for cranking it down too tight. Got it off with some channel locks and a torch. Bolts ruined of course but another is on it's way and shall be here Sunday.
But let it be a lesson to be learned: know your strength and don't use it on your drain bolts!
Tromper
  • Seattlish
Re: Stripped the head off my drain bolt
« Reply #1 on: November 18, 2017, 08:42:14 AM »
Wait...You mean I shouldn't be using my impact wrench on those?
2008 SYM HD200 "Niwanibiz"
k9 S200 (Blue) "Max" (Sold)
« Reply #2 on: November 18, 2017, 01:11:03 PM »
You talking the larger alloy cap on engine bottom, with the spring and screen? That thing is often overtightened, and often stripped on all brands of Asian scooters.
If it was the big oil drain plug stripped....that is rare bad luck. Let's hope that guy never touched the spark plug!
ole two wheels
  • ole two wheels
« Reply #3 on: November 21, 2017, 12:11:10 AM »
Revsin, tell me I didn't hear you say you used a torch, as in acetylene and oxygen???? I hope you meant, as in propane. If you put the blue tip wrench on that alloy, you're braver than me.
Mac
2012 Kymco DT300
1996 Honda Shadow Spirit 1100
Mr. Paul
« Reply #4 on: November 21, 2017, 12:23:18 AM »
Thats overkill Tromper. I find a cheater bar and red Locktite works just as well.  :D
2009 Kymco People 150
1993 Honda Helix
revsin
« Reply #5 on: November 21, 2017, 11:03:47 PM »
No, just plain ole blue bottle propane torch. After all, I was only trying to drain the oil with gravity. Not create a pressure cooker bomb full of molten oil!
big blue
« Reply #6 on: November 22, 2017, 12:13:12 AM »
If you are loosening the 17mm plugs (either one) get a 6 point socket head not a 12 point and you will have far less chance of what just occurred.
« Reply #7 on: November 22, 2017, 01:47:16 AM »
  use blue locktite you wont need a cheater bar and it holds very well
ole two wheels
  • ole two wheels
« Reply #8 on: November 22, 2017, 02:36:54 AM »
Question? Why would you use any color Loctite on an oil drain plug???
Mac
2012 Kymco DT300
hypophthalmus
« Reply #9 on: November 22, 2017, 02:44:06 AM »
Agreed, a much better solution is to weld it on.
Tromper
  • Seattlish
« Reply #10 on: November 22, 2017, 04:22:04 AM »
I dunno if loctite will do it.  That's a real important bolt..maybe some JBweld.
ole two wheels
  • ole two wheels
« Reply #11 on: November 22, 2017, 08:19:37 PM »
If I read it right, revsin said he striped the head  not the thread. Loctite nor J B Weld will fix that' If he can't file or grind it down to a smaller hex, then the only option is to purchase a new plug. AGREED?
Mac
2012 Kymco DT300
Tromper
  • Seattlish
« Reply #12 on: November 22, 2017, 10:53:30 PM »
I wouldn't even file it.
Regardless if it's the screen bolt or the actual bolt just replace it.  Cheap and less work for better result.
Mr. Paul
« Reply #13 on: November 23, 2017, 12:46:40 AM »
Tromper and I were both joking. Guess it was lost in translation. :-[
1993 Honda Helix
ole two wheels
  • ole two wheels
« Reply #14 on: November 23, 2017, 02:29:43 AM »
Yelp, I was wondering how loctite or glue could help a rounded off hex. Tromper has the right idea. For all the work trying to salvage a mangled plug, it would best to get a new one. Don't know why folks find it necessary to tighten them to that extreme anyway.
Mac
2012 Kymco DT300
