..well, that's wat the bendix does, it extends to the drive face when the starter motor spins it...
..if the starter motor's output shaft isn't long enough, it will not spin the bendix..
..you can easily see this by removing the cvt cover, and taking a look at it...
..should be able to see the end of the motor's output shaft where it's teeth mesh with the teeth of the bendix...
