Author Topic: startup and variator  (Read 3490 times)
art
Re: startup and variator
« Reply #30 on: August 05, 2010, 05:58:29 AM »
Nothing is impossible!!!  But you will need some tools  ;)
jay20
« Reply #31 on: August 05, 2010, 11:46:10 AM »
the cog that the bendix goes onto seems quite stiff it still turns but cant do it by hand is usual or is there summat wrong?
« Reply #32 on: August 05, 2010, 12:57:44 PM »
..do you mean the one that's about 4 inches in diameter??
..if so, that's your drive face, and the stiffnes is a result of the cylinder's compression...
..did you verify that the bendix is spinning in the right direction?
..there has been instances where a newly installed starter motor would turn backwards...
jay20
« Reply #33 on: August 05, 2010, 01:31:30 PM »
when the bendix spins it spins anti clockwise and comes out...how do i change it to clockwise?
« Reply #34 on: August 05, 2010, 09:43:11 PM »
..imma have to google the fix for that one, because it has only one wire for voltage..and a ground wire that is attached by a screw...
..anybody know how to reverse the polarity of the starter motor??
« Reply #35 on: August 05, 2010, 10:27:48 PM »
..are you saying that it falls out of it's seat? or extends....
jay20
« Reply #36 on: August 05, 2010, 11:07:13 PM »
no i mean it comes out to the other cog but then it stops so is that weak battery?
« Reply #37 on: August 06, 2010, 12:04:13 AM »
...possibly..
..but we need to combine these two threads...
..im getting confused...lol..
..post on the other one with the vid..k?
peace
sefton
« Reply #38 on: August 06, 2010, 01:11:16 PM »
my electric starter wont work does any1 know how i can fix this please ??
jay20
« Reply #39 on: August 06, 2010, 01:43:06 PM »
have you took your starter motor out n see if it spins?
« Reply #40 on: August 07, 2010, 01:59:12 AM »
..also, make sure the wire is connected to the motor...
..mine fell off once before...
..what happens when you try to start your scoot with the pushbutton??
..i ask because there are MANY reasons a starter won't run...
..let's narrow down the possibilities..  ;D
peace
