Author Topic: Who's up for a challenge? Please help!!!! - Like 50 4T CDI saga....  (Read 5766 times)
Glennza
Re: Who's up for a challenge? Please help!!!! - Like 50 4T CDI saga....
« Reply #15 on: July 27, 2010, 07:54:46 AM »
I have the same Australian model black Like 50 4T, now one week old. The dealer told me that it did not have a restricted CDI. How can I tell? Please excuse my ignorance, I haven't been on a bike in over twenty years.
art
« Reply #16 on: July 27, 2010, 06:42:42 PM »
If you can go over 65 klm or 45 mph you should be de restricted,you may need to be going down hill to do this.
Glennza
« Reply #17 on: July 28, 2010, 08:39:43 AM »
Nope, can't go faster than 65kmh. Wonder how the OP went with his mod?
art
« Reply #18 on: July 28, 2010, 08:51:12 AM »
You may have a restricter in the veriater drive boss,look around a bit you will find some info on it.The cdi restriction will cut power to the sparkplug and is quite noticable,almost like its cutting out. I'd start there.
Glennza
« Reply #19 on: July 28, 2010, 11:37:19 AM »
The restricted drive boss will be swapped out at first service. Will need to work out how to do the CDI mod.
art
« Reply #20 on: July 28, 2010, 06:11:23 PM »
It may allready be you'll know when it kicks in. The drive may be holding you back from reaching the speed needd to activate it. If you get over that 65kl hump with no hickups you are there.  Till ya start modding it of corse ;D
jbcinzio
  • I was the second gunman on the grassy knoll....
« Reply #21 on: July 28, 2010, 08:11:19 PM »
G'day Glennza!
In response to your questions, after much deliberating I have come to the conclusion that The Like 50 4T does NOT have a rev-limiter on the CDI.
I have spent many many hours trawling the forum's, chatting with dealers and googling and have been assured that there is nothing cutting off the power at a certain rpm/speed.
However, there are 3 things that will be holding us 4T riders back...
1/ Variator Drive Boss. Modifying that drive boss at first service (same time as mine) will do wonders! - The thing rides like a new machine, and you can enjoy 70 - 75km/hr on the flat, and 80 - 85 on a slight downhill. The up-hills are another story though....  :(
2/ Breathing is a big issue. From what I understand, changing the exhaust will do wonders. Obviously, if the CDI isn't restricted and its running out of steam on a downhill, then it probably can't get the air out fast enough! I've Just ordered a LeoVince SP3 exhaust from Italy that is still reasonably quiet, but will flow much much better.
3/ Fuel. With a better exhaust bolted on I believe that the stock (19mm) carb will be the next thing to hold me back. Even with bigger jets and a pod filter, there's only so much air the lil' sucker will er.. suck.
Now I've just ordered a 24mm Keihin CV carb that while some disbelievers will argue that its too big, I am told that I can always restrict the inlet side of things should I need to. Well it's easier to do that rather than trying to force more air down a smaller carb now, isn't it?
Good choice of ride, too.... although i'm slightly biased  ;D
Happy Scooting,
Josh.
This message was posted using 100% recycled electrons.
« Reply #22 on: July 28, 2010, 09:38:36 PM »
...excellent post jb!!
..good luck with you 24mm carb!!
..i bet you'll love it!!
jbcinzio
« Reply #23 on: July 29, 2010, 12:15:58 AM »
Cheers 'Slinger  ;)
Hopefully I'll crack the elusive "Comfortable" 85 km/hr....
As they say, The proof is in the riding!
Josh
« Reply #24 on: July 29, 2010, 12:20:44 AM »
..i have a 20mm Keihin CVK that i had on my guilty once before...
..imma put it back on tomorrow...can't wait to see what i can get out of it now....
 :o
jbcinzio
« Reply #25 on: July 29, 2010, 03:45:51 AM »
Well good luck 'Slinger & let me know how you go!
When you get a chance, can you let me know your thoughts on the best way to optimize my CVT/Clutch?
I'm wanting to know what you're using in your 4T, and what you'd recommend.... (can be 2 completely different things, yes?!)
Josh
