Author Topic: Oil Leak from the bottom  (Read 954 times)
ptingib
  • mitapXD
    • Top-notch ?asual Dating Verified Damsels
« on: November 23, 2017, 12:54:31 AM »
Hi can anyone help,  i did an oil change and instead of just taking out the nut on the side i took out the bolt at the bottom.  i cleaned it all and everything was ok except the plug/big bolt actually cracked and as such when I put it back its was not a complete sealed unit and it drips all day on my drive losing oil.
what is the best sealant, glue or paste i can use to cover the cracked item and hopefully stop the leak.  ive got an mark II xciting 500 ri,
cheers for any advice
jeeves
  • Dubrovnik, Croatia
Re: Oil Leak from the bottom
« Reply #1 on: November 23, 2017, 12:52:29 PM »
Buy a new bolt.
Agility City 125
Mr. Paul
« Reply #2 on: November 23, 2017, 01:22:21 PM »
Buy a new bolt.
Thats the best fix for sure Jeeves! The item can be found at KymcoPartsMonster. If I am correct, it is part #11332-KED9-900. I would replace the O-ring also.
2009 Kymco People 150
1993 Honda Helix
« Reply #3 on: November 23, 2017, 01:37:56 PM »
Also, take a look at the GY6 OIL SCREEN FILTER on ebay. It might be the same....and prices range from $3 to $10 for the 4 pc. kit. Good idea to keep a spare kit in the tool box since these all seem to be made out of poor quality metal.
Freq. fail due to having been overtightened.
